Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-13-2011, 11:02 AM   #1
Installing shower pan. How do I measure a mortar layer thickness?
Hi,
I am remodeling my bathroom. I am going to install a new shower pan. The installation instruction says: "Place up to a 1/2" thick layer of mortar/thinset on the floor. Taper the mortar/thinset to 1/4" thick around the floor drain."
My question is how do I measure 1/2" thick layer? Do I have to use a trowel with no notches and somehow measure layer thickness? Or, can I use a 1/2" notched floor trowel?
Thanks.
sukhenkoi is offline   Reply With Quote
Old 04-13-2011, 05:06 PM   #2
When I set an acrylic shower base, I mix setting compound and rough lay it based on the base contours. I place a 4mil plastic over the top completely covering the compound. I place the base down over it and press it into position. Once it's set, I lift it up and look at the impression in the plastic. If there are no gaps, I put it back and let it dry. If there are gaps ,I repeat the procedure until I'm happy.
The excess will squeeze out if you haven't overloaded the floor.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
sukhenkoi (04-14-2011)
2x6 Joist Spacing and Subfloor Thickness for Shower Pan rjschwar Tiling, ceramics, marble 2 03-01-2011 07:34 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Installing a Shower Blaze25 Plumbing 2 10-13-2008 08:32 PM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
