Installing Shower Pan On A Concrete Floor - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2008, 08:15 PM   #16
Just a thanks for all the help on the show pan install. Got the pan in and inspected. Spent serveral weekends tiling it and had our first guests us it over the holiday.
Happy New Year
sv9779 is offline   Reply With Quote
Old 12-31-2008, 08:23 PM   #17
Here is a utube video that shows the shower drain
Old 03-13-2011, 12:53 AM   #18
Originally Posted by thekctermite View Post
OK Steve,
Throw out the poly sheeting. You need rubberized shower membrane material. Poly won't cut the mustard.
On the basement slab, you need a bond break. I'd use either 15# building felt of even Ditra. You don't want the shower's base bonded to the slab. Trust me, it isn't going anywhere.
Then, you need a pre-pan that is sloped to the drain. Your water membrane will sit on this.
Let's talk "mud." You DO NOT USE CONCRETE in a conventional sense. You must use a mix of three parts clean dry sand to one part portland. This mix is available at tile suppliers. Per 50# sack, you mix in 1/2 gallon of water...No more. The lack of water makes it super strong. It will be the consistency of wet sand, but not "plastic" like concrete. The mud is packed into place using a trowel or float. Pack hard. It should be no less than an inch thick at the thinnest part, give or take a little. Sprinkle a little water on the surface once you've got it all shaped and looking good. I'd also recommend covering it with something (like the poly) to help it cure without too much evaporation. Once dry, remove the covering.
Once the pre-pan is cured for a day or more, apply the membrane. The membrane goes at least several inches up the surrounding walls and also gets incorporated into the curb. Use no fasteners except at the very top...Roofing nails work well, nailed into the studs. You'll have to fold and overlap at corners, and they also make a solvent weld cement to make it easier. The membrane must be incorporated into the drain. They make special drains that clamp the membrane, available at tile suppliers. Also, your membrane should go under your cement backer board on the walls. Do not fasten the cement backerboard to the studs through the membrane. You need a few inches to hang down with no nails or screws. If you penetrate the membrane too low, it'll leak.
Now set your drain.
Now you're ready to place your final mud base. It is done the same way as the pre-pan, with the same mix, packed in place. I did mine about 3" thick, tapered to about 1-1/2" at the drain. You must have at least 1/4" per foot of slope. In the same "pour" as the final base, you should form your curb and place it as well. Same material. I always incorporate some strips of metal lath for reinforcement. That's overkill, but it makes me happy. Be sure to slope the curb toward the drain if you're using a swinging shower door. If glass/track are being sealed to the curb, the slope is less critical.
You'll need some basic concrete tools to do the pre-pan and base. A 12" wood or magnesium float is perfect. I'd also suggest a small trowel, like a margin trowel. These are helpful for packing and smoothing the base as well as the curb.
I'd recommend going to a good tile supplier to get your membrane, base mud, and thinset. Their quality is typically better than what you can get at box stores. DO NOT USE PRE-MIXED THINSET. And for God's sake do not use mastic. Use dry mix modified thinset.
Just two more suggestions...
Be sure that you waterproof your walls' backerboard. Cement board, grout, and tile are not waterproof. RedGuard is a paint-on product that works great. It goes on the board, and once dry, you can tile. This is an incredibly important step.
Also, don't forget to mud and tape the cement backerboard's seams and corners. Use mesh fiberglass tape made specifically for backerboard. Use thinset to fill the joint, bed the tape, and cover the tape. Just like drywalling, only looks don't matter.
Hope all this helps.
Hi I'm Chris, I'm getting ready to remodel my bathroom in my parents house. The bathroom is on the down stairs so there is a concrete slab. I've done tile work but never build a shower pan. Current shower pan is fiberglass which I plan to remove. I was searching and found this thread on how to build a shower pan on a concrete slab.
The builders felt how are you attaching that to the concrete or is just floating? Then I build the first layer of the pan right on top of the felt using concrete floor mix? Then membrain then the final layer of the mud. Once dry can start laying tile? I'm not one to read and understand, more of a hands on type of person.
cvanden8712 is offline   Reply With Quote
Old 03-13-2011, 01:14 AM   #19
Hi Chris, My gosh, I forgot how long ago I put that shower in! 2008. Anyway, I really can't remember all the steps. Which is problematic because I have to do another one soon. I did get something called a Quick Pitch shower kit. It slops the drain for you. I still have one in the shop for the next shower. Do a Google search for Quick Pitch Shower and you'll see it. There are also lots of YouTube videos that show all the steps you need to do. I also do better when I can see it done. Now you can also get Kirdi water proof membrains and floor kits. A Google search for Kirdi Shower will get those results.
Good Luck
Steve
Old 03-13-2011, 11:03 AM   #20
Thanks Steve, Ill look into those.
My biggest worry right now is where I start. I know roughly how big I want the curb for the entry of the shower. Just trying to figure out what goes on the floor first.
Shower floor grout cracking radnrs Flooring 11 09-14-2008 09:49 PM
Shower floor confusion heatherfeather Remodeling 17 06-25-2008 10:36 PM
Shower floor slope Not Sure Building & Construction 11 06-10-2008 12:12 PM
Shower floor base project man General DIY Discussions 2 02-23-2008 08:35 PM
