#1 |
Installing Shower door - opening out of square by 3/4"
Searched the forum and found a conversation or two regarding this subject - not entirely helpful based on my situation.
48" inch shower pan with backer board. Left to right measurement between finished tile wall at base is 46 1/2" and 47 1/4" at top (70" off top of shower pan). I am assuming the doors themselves can be plumbed to compensate for the variance. Anything that I should be concerned about or tips/tricks to take into consideration before i install my $300 shower door? |
#2 |
I've never seen a door that can be adjusted that much.
Going to need to frame the opening I'd bet. Even if you could adjust it some your going to end up with a 3/4 tapered gap and look like poop. |
#3 | |
Installing Shower door - opening out of square by 3/4"Quote:
I think I am going to add to measure twice cut once, plumb, plumb and plumb! |
#4 |
That would be framing 101.
#5 |
Reframe? Are you telling me that I need to pull the tiles and frame a new opening? That doesn't sound feasible at this point. Do you have a trick?
#6 |
I failed all my 101 classes! Did ok in my 202 classes though!
#7 |
Not so new
I'm afraid joe may be right. Most shower doors give you a little adjustment
on each side but 3/4 may be out of the range. Maybe cut a PVC tapered wedge or something. However you do it, it'll surely be noticeable. |
#8 |
I am going to give it a shot ... I once learned the difference between a DIYer and a Pro is the pro knows how to cover their gaffs! wish me luck ... Will post when I am done.
#9 |
I would at least hope that one side is level - and that will be the hinge side. Make your adjustment on the other side.
#10 |
would it be possible to add in some framing, level and tile it and buy a smaller door?
#11 |
Almost done .... I think I can make some additional adjustments on the doors ...
#12 |
Might want to check the hole for that shower control is big enough to get the screws in the trim plate.
Sure looks small. |
#13 |
Thanks Joe ... Darn it .... Another rookie mistake i am afraid!
#14 | |
#15 |
Where did you buy your enclosure? A lot of manufacters make shower doors that will fit an "up to" opening... It requires a little cutting on you part but in the end it will end up plumb and sqaure
| Display Modes | |
| Installing shower unit inside bathtub | mlinpdx | Plumbing | 2 | 11-29-2012 01:03 PM |
| need help installing shower door | master Plumber | Plumbing | 2 | 11-06-2012 08:02 AM |
| Installing basement shower drain | atilla137 | Plumbing | 5 | 09-03-2009 12:54 PM |
| Installing Corner Countertops on a corner that is not square? | tjandt | Remodeling | 10 | 12-30-2005 11:26 PM |
| Installing a one piece shower... plumbing issues | singforsupper | Plumbing | 2 | 06-01-2005 09:26 AM |
