-   -   Installing Shower door - opening out of square by 3/4" (http://www.diychatroom.com/f15/installing-shower-door-opening-out-square-3-4-a-170238/)
aaldrich55443 01-27-2013 09:49 AM
Searched the forum and found a conversation or two regarding this subject - not entirely helpful based on my situation.
48" inch shower pan with backer board. Left to right measurement between finished tile wall at base is 46 1/2" and 47 1/4" at top (70" off top of shower pan). I am assuming the doors themselves can be plumbed to compensate for the variance. Anything that I should be concerned about or tips/tricks to take into consideration before i install my $300 shower door?
joecaption 01-27-2013 09:55 AM
I've never seen a door that can be adjusted that much.
Going to need to frame the opening I'd bet.
Even if you could adjust it some your going to end up with a 3/4 tapered gap and look like poop.
aaldrich55443 01-27-2013 10:08 AM
Framing? Are toy telling me that I need to remove my tiles, and reframe a new opening? Or is there a short cut / trick to this?
I think I am going to add to measure twice cut once, plumb, plumb and plumb!
joecaption 01-27-2013 10:10 AM
That would be framing 101.
aaldrich55443 01-27-2013 10:11 AM
Reframe? Are you telling me that I need to pull the tiles and frame a new opening? That doesn't sound feasible at this point. Do you have a trick?
I failed all my 101 classes! Did ok in my 202 classes though! :)
12penny 01-27-2013 11:29 AM
I'm afraid joe may be right. Most shower doors give you a little adjustment
on each side but 3/4 may be out of the range.
Maybe cut a PVC tapered wedge or something.
However you do it, it'll surely be noticeable.
aaldrich55443 01-27-2013 01:28 PM
I am going to give it a shot ... I once learned the difference between a DIYer and a Pro is the pro knows how to cover their gaffs! wish me luck ... Will post when I am done.
tribe_fan 01-27-2013 01:42 PM
I would at least hope that one side is level - and that will be the hinge side. Make your adjustment on the other side.
princelake 01-27-2013 02:30 PM
would it be possible to add in some framing, level and tile it and buy a smaller door?
aaldrich55443 01-27-2013 04:17 PM
8 Attachment(s)
Almost done .... I think I can make some additional adjustments on the doors ...
joecaption 01-27-2013 05:14 PM
Might want to check the hole for that shower control is big enough to get the screws in the trim plate.
Sure looks small.
aaldrich55443 01-27-2013 09:04 PM
Thanks Joe ... Darn it .... Another rookie mistake i am afraid!
randen89sc 01-31-2013 11:14 PM
Sure looks small.
Good call I did same thing and had to drill and cross my fingers I hit the threads through my tile!! I hit first try!i have 48" as well but really want to do a single glass door.
jakmilwaukee 02-10-2013 07:50 PM
Where did you buy your enclosure? A lot of manufacters make shower doors that will fit an "up to" opening... It requires a little cutting on you part but in the end it will end up plumb and sqaure
