Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-26-2010, 01:57 PM   #1
Installing Range Hood and Stainless Steel Backsplash
Will be installing the range hood this weekend but I have a couple of questions if someone could answer them. I purchased the spagna vetro 30" SS hood but I was wondering what the distance should be between the bottom of the hood and the top of my freestanding range. I've read that the bottom of the hood should be 60" from the floor. Also should the stainless steel backsplash be installed first and then the range hood?
oguevarra is offline   Reply With Quote
Old 02-26-2010, 05:01 PM   #2
Newbie Bill
Nice looking range hood.
According to the link you provided, it should be 28 to 31 inches above the cooktop.
If you are taking the back splash up to the bottom of the range hood, I don't see why the back splash can't be installed after.
900 CFM, wow, that is a lot of CFM.
Are you running the venting for this range hood to the outside (ie through the wall or roof), or are you using the ductless conversion (ie. vents back into the home)?
For outside ducting, the installation calls for minimum 6" vent pipe, rigid ducting highly recommended. What are you using?
Last, but likely the most important question for you... Are you aware that these high CFMs range hoods can create a negative pressure environment in the home causing flew gases from furnace/hot water tanks/fire places to be sucked into the home? Precautions must be taken to ensure your families safety.
I don't have the knowledge on how to handle this last issue so perhaps some of the Hvac experts will have some comments.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Range hood install questions drtbk4ever Building & Construction 6 10-09-2009 10:00 AM
Range hood wiring question, help!! nyc_apt_dweller Electrical 4 03-05-2009 09:34 PM
Range hood and microwave shelf install??? osueric27 HVAC 2 01-05-2009 01:01 AM
Range hood installation, termionating at ceiling gorf Appliances 3 12-04-2008 10:28 PM
