Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-24-2008, 09:25 AM   #1
DIY Expert in Training!
Installing prehung door in 2x3 wall???
My basement was framed with 2x3's. I am replacing two doors and bought prehung that have 4 1/2" jams. With the wood (2.5" and dry wall .5" x2 that leaves me with a 1" gap. I was thinking of centering the jam then after I dry wall I can rip casing to the width of the trim and just pack out the trim on each side an extra 1/2".
Thoughts?
gone_fishing is offline   Reply With Quote
Old 02-24-2008, 11:57 AM   #2
Custom Cabinet Maker
That will be the easiest way. Simplest way is to mark where the trim will be on wall and pack everything out before you put trim on if you can. Second is to cut your trim first then attach the packing to the trim and then nail it on.
skymaster is offline   Reply With Quote
Old 02-24-2008, 02:47 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Another option is to install the pre-hung door and center it (by wall depth) in the opening.
Then, when you are installing the casing onto the jambs, use 1/4" fir strips on the backsides of the casing edges (Wall edge) - on each side of your door.
- Build Well -
Old 02-24-2008, 08:23 PM   #4
remodeling pro
I would glue the proper thickness pieces onto the back of the trim, and tack with a couple of brads, , then sand the seam flush before cutting and installing the trim. It would be less obvious to do a smaller buildout on each side (center the jamb as you plan), than to do the full 1" on one side. But if the doors happen to be inconspicous, like a closet or storage area, or little used bath room, you could do the full 1" on the "hidden" side of the jamb, provided the swing of the door is appropriate for it.
You could also use a straightedge to rip the jambs to the proper width before hanging the doors. When I plan on narrowing jambs, I do not like the small awkward space it leaves between the factory door stop and the edge of the jamb, so I remove the stop and rip a new wider stop that will reach to the full width of the finished jamb. This stop makes a perfect straight edge for a bearing guided flush trimming bit in a router, and the jamb merely ends up looking like the rabbited material used for experior doors.
troubleseeker is offline   Reply With Quote
Old 02-24-2008, 08:52 PM   #5
I installed the 1" on the inside of the laundry room. Because of the exposed studs and new wall on the right I will either pack out 1" when doing the trim or possibly put ferring stripes up then dry wall over that.
More On This Topic
Hi! I'm Karina Fraley for Expert Village and today I'm showing you how to make a photo frame Christmas tree ornament out of felt. We've gone ahead and we've made our little frame. We've cut our felt, we've made our little opening, chosen our picture, and... Read More »
Detailing your vehicle is an important step to maintaining the car's condition and value. If corrosion, residue and other gunk is allowed to build up on the working components of your vehicle, they can lead to malfunctions in the parts. This is true for... Read More »
How to Caulk Trim
How to Caulk Trim by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Okay now we're going to talk a little bit about caulking interior door jambs. Now, this is very different from anything else you caulk, Now this is... Read More »
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now we're going to talk a little bit about spackling on a door jamb. Now, earlier we talked about spackling walls. Now interior or exterior walls... Read More »
Hi! I am Bob Osborne with Expert Village. Cleaning doorjambs is a lot easier than most people think. If you use the same cleaner that you are using on your wheels and most of these cleaners, you do not have to worry about any problems on materials like... Read More »
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
Installing New Wires In Wall? madcitysw Electrical 5 01-14-2008 09:08 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
