-   -   Installing New Interior Doors... Question. (http://www.diychatroom.com/f15/installing-new-interior-doors-question-34619/)
TPhillips 12-29-2008 01:07 PM
First time installing doors. I'm going with just the slabs instead of pre-hung. I bought a router and jigs for the hinge mortis and latch plates. On the first door I did, I installed it in the jamb, shimmed it to fit the way I wanted and marked my hinge points. I mortissed the hinges and re-installed the door. Everyhting was perfect except the door is too wide. Come to find out, the original doors are 29-7/8" wide and the slabs are 30" wide. I bought a power plane to take the 1/8" of material off, but some guys at the office are telling me it won't work.
Question is, what is the "proper" way to shave the door edge down? Can I use the power plane with any success?
Thanks!
bradnailer 12-29-2008 02:08 PM
I'd trim the door with my table saw. But, I don't have a power plane. The plane should work just fine but make sure you keep it square to the door edge and don't try to take off too much material with each pass.
TPhillips 12-29-2008 02:15 PM
I'll be sure to keep it square... I was told it would make the edge "wavey". But I'm not sure how that would happen, with the way the gaurd is set up on the power plane. I need about an 1/8", so I'll take 2 passes @ 1/16" each. The plane does up to 3/32" per pass.
Worse come to worse, the doors are only $25, a small price to pay for experience! :wink:
Thanks,
Tim
timthetoolman 12-29-2008 04:49 PM
Yea i'd use the planer if i were you. I've used this in the past with no troubles. I would first draw a line preferably on the hinged side (for appearance) where you will be shaving it down to. Then it is a good idea to score the top and bottom of the door at your line with a razor knife. This will avoid the planer chipping the bottom and top of door with each pass, which does happen. And walah your door fits.
TPhillips 12-29-2008 04:55 PM
Cool, I'll try that. And yes, I was going to do the hinge side anyway. ;)
Termite 12-29-2008 05:05 PM
I'd use the jointer (ideally) or the tablesaw, because the hand power plane will be much less accurate.
However, it can certainly be done. Draw a dark pencil line the length of the cut representing the desired depth to be removed. Take light passes of 1/32" or so and plane to the line, just removing it.
Sand the edge and chamfer the edges with sandpaper.
fhivinylwindows 12-29-2008 06:14 PM
If you use a planer they generally have a bevel so keep changing your direction or you will end up with an ugly angle.
TPhillips 12-30-2008 08:11 AM
Thanks for the input fellas. I used the power plane last night and it worked perfectly. I'm a bit of a perfectionist, and it really did a nice job. I took 2 passes with it set at 1/16", then I set it to 1/32" and did a nice 45* bevel on the edge.
With the house being built in 1968 and my reluctance to buy pre-hung doors, this plane will come in handy over the next few days (years).
BTW, I'm using the Ryobi HPL51K.
Crappy cell phone pic:
http://img519.imageshack.us/img519/224/doorsep8.th.jpg
