Installing New Front Door...... Any Tips ????? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 10:09 PM   #16
Here is the picture of the original door witch you can see it just sits on the concrete slab .... now I don't know if this is correct or not
ogoz23 is offline   Reply With Quote
Old 05-12-2012, 10:11 PM   #17
I'm sorry but can you please explain what a sill flashing is in a more elementary way I've never done it ..
Old 05-12-2012, 10:17 PM   #18
kwikfishron's Avatar
Rewards Points: 194
Originally Posted by sixeightten View Post
Do not use drywall screws there. They will rust eventually. At the very least, you should provide a sill flashing, even if it is just tape and not metal.
Agreed on the screws but how is tape or metal going to help if that step isn't dealt with?
kwikfishron is offline   Reply With Quote
Old 05-12-2012, 10:20 PM   #19
Framing Contractor
Rewards Points: 112
I see the problem now in the earlier pic. I agree with Ron, lose the step or the bottom of the new door will soon be rotted.
sixeightten is offline   Reply With Quote
Old 05-12-2012, 10:20 PM   #20
I don't know if this matter but the house is on a concrete slab and there is no tile.... I was going to install the front door first then tile the house I'm I doing this backwards?
Old 05-12-2012, 10:21 PM   #21
This is exactly why I'm replacing this door because the bottom is rotten , witch step is this ?
Old 05-12-2012, 10:37 PM   #22
Rewards Points: 194
This one, the brick.
Old 05-12-2012, 10:41 PM   #23
Ok that's some tile that was left over you guys are saying to remove this tile ? And apply sill flashing and then I can tile on top of the sill flashing ?
Old 05-12-2012, 10:42 PM   #24
Mind you the door is about 6 inches before that step
Old 05-12-2012, 10:44 PM   #25
Framing Contractor
Rewards Points: 112
Water, snow, wet leaves, etc will lay on that brick ledge, against the door, and slowly rot out the bottom. Same as the previous door. If you can remove that "step", the water will not lay against the door.
Old 05-12-2012, 10:46 PM   #26
How can I remove that step , that's the hight of the concrete slab for the interior , the only way I can think in removing the step is raising the hight of the concrete in the outside of the house ?
Old 05-12-2012, 10:49 PM   #27
Rewards Points: 194
Exactly, that "is" the problem.
Re-read the post of this thread.
Old 05-12-2012, 10:51 PM   #28
Should I install the door right at the edge of the steps , that way the door is not sitting 6 inches behind the steps ?
Old 05-12-2012, 11:03 PM   #29
Or maybe I can cut with a concrete saw 6 inches off that step
Old 05-13-2012, 07:47 AM   #30
Rewards Points: 194
That step looks like brick faced with tile, Once the door is out it should be no problem to just pop the brick out of there.
After that, you would create a new step that would be the same height as what you have now (flush with the slab) but would only protrude out as far as the new door jamb.
Once that's done you're ready to install your new (yet to be built) pan flashing which will contain both the door and the sidelight and keep the water (at the bottom anyway) from entering you home.
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 07:24 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Tips for installing crown molding as a on man job? gmhut Carpentry 3 05-14-2009 07:21 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 11:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 01:47 PM
