Installing New Front Door...... Any Tips ????? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-10-2012, 06:01 PM   #1
Installing new front door...... Any tips ?????
Well guys I'm doing a new project , I'm installing a new front door and I was wondering if you guys have any tips for example the door is not screw to the frame, do I install the frame first or first screw the door hinges to the frame and then install the door. Second my screws for the door hinges are 1 inch long , the door place that sold me the door recommended to use 3 inch concrete screws that way the screw goes through the hinges ,door frame and hits the concrete . What are your thoughts on this ? Also my dad told me to put some glue on the hole where the screws go . Any tips ?
ogoz23 is offline   Reply With Quote
Old 05-10-2012, 07:33 PM   #2
Rewards Points: 13,978
Need a picture.
You do plan on a prehung door not a slab right?
Old 05-10-2012, 08:26 PM   #3
You lost me , what's the difference ?
Old 05-10-2012, 08:31 PM   #4
A slab is just the door, no jambs.
Prehung comes all assembled, just slid it in place.
Trying to get a slab door to fit an existing door opening is a royal pain and would take longer to do in most cases then a prehung and may not seal as well.
Old 05-10-2012, 08:36 PM   #5
Ok its pre Hung then
Old 05-10-2012, 08:43 PM   #6
Without a picture it's hard to give you tips on how to do it.
In my opion the best doors are vinyl jambs, vinyl brick molding, fiberglass door, adjustable sills.
That way there's no rot, no more painting, if the floors not level the sill can be adjusted.
Old 05-10-2012, 09:12 PM   #7
Ok this is the pictures shows the door the frame on the left and then the sidelight witch I have to attach to the frame so its one peace
Old 05-10-2012, 09:14 PM   #8
This is where is going and should end up looking like this
Old 05-10-2012, 09:18 PM   #9
The door is fiberglass with a PVC frame , I just kind of confuse on how to put everything together , should I attach the side light to the frame first then install the frame with the side light and at the end attach the door with the hinges ...?
Old 05-10-2012, 09:21 PM   #10
Your going to have a mess on your hands trying to get all this to work and not leak.
Old 05-10-2012, 09:33 PM   #11
Ok thank you for that but the fact of the matter is that I have to get it to work and this is my project. Thats why I'm asking for help in the forum the door was taking apart for paint and now is all disassemble there for I need to know what's the smartest way in tackling this project .
Old 05-12-2012, 01:43 PM   #12
Anyone ?
Old 05-12-2012, 03:17 PM   #13
kwikfishron's Avatar
Rewards Points: 784
That step is an issue, I’d start by getting rid of it as is and have the step up right under the threshold, then you can have a door pan flashing made at any sheet metal shop as a one piece unit to for both the door and the sidelight to sit on. That will keep water from getting in at the bottom.
Is your new sidelight the same height as the new door?
How about height and width of the new units compared to the opening you have now?
This is a basic door pan.
kwikfishron is online now   Reply With Quote
Old 05-12-2012, 09:05 PM   #14
The sidelight is the same height as the door frame , basically from what I see I have to put everything together first connect the sidelight to the frame I was going to glue it and then screw it with drywall screws , then I was going to attach the door to the hinges , that way everything is in one piece . As far as the threshold I don't have a water problem I'm going to just let the door sit on the concrete slab and then just tile around it .... This door frame is1/2 inch thiner from the original door
Old 05-12-2012, 09:08 PM   #15
Framing Contractor
Rewards Points: 120
Do not use drywall screws there. They will rust eventually. At the very least, you should provide a sill flashing, even if it is just tape and not metal.
sixeightten is offline   Reply With Quote
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 06:24 AM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Tips for installing crown molding as a on man job? gmhut Carpentry 3 05-14-2009 06:21 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
