Installing Medicine Cabinet - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-23-2009, 06:29 PM   #1
I cut a hole in the dry wall to install a new medicine cabinet and there is a 2x6 in the way. There is a 2x6 to the right but a PVC pipe to the left. Can I just cut out the section in the way if I add a 2x4 for the cabinet to sit on and secured it to the 2x6, or do I need to reinforce the 2x6?
jingoism is offline   Reply With Quote
Old 11-23-2009, 07:41 PM   #2
ArmchairDIY's Avatar
It depends.
I know thats not the answer you were hoping for. But you need to determine if the wall is a bearing wall or just a partition wall before you can decide how to proceed. a bearing wall is supporting the structure of your home. a partition walls only function is to create a room.
Don't cut out any studs until you know for certain what function they serve.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself!
ArmchairDIY is offline   Reply With Quote
installing switch in side of cabinet sm99 Electrical 1 06-03-2009 08:21 AM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
Question on installing cabinet door hardware Boatnuts Remodeling 4 03-19-2007 09:46 AM
Medicine Cabinet sherlock Remodeling 13 11-21-2005 10:23 PM
