Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-17-2010, 08:41 AM   #1
Installing Knotty pine to vaulted ceiling
I want to install the pine boards to my ceiling, but the ceiling has stucco on it. Do I have to remove the stucco before I begin installing the boards?
atonkennedy is offline   Reply With Quote
Old 09-17-2010, 09:03 AM   #2
You can save a great deal of time and clean-up by firring out the rafters. Use a decent grade of wood also, not those crappy 1X3s you see. Probably could rip 1X8s into thirds and use that as firring strips. Then screw them to the rafters - be sure you find centers for anchoring. 2 1\2" screws should be good. And if you're tapping into some old lumber - say oak or GA Loblolly Pine, you'll drill pilot holes.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 04:44 AM
Lighting tip needed for vaulted ceiling wease Electrical 5 02-25-2007 12:49 AM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
Installing a ceiling light fixture? DK75 Electrical 7 02-27-2006 09:10 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
