Installing Interior Door At Bottom Of Stairs - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 09:10 PM   #1
newer than a newbie...
Rewards Points: 83
Installing Interior door at bottom of stairs
Hi there
From our main living area/kitchen/hallway, there are 7 steps that lead down to our family room in our side-split home.
About 3 feet from the foot of the stairs, there is an opening for which we'd like to install an interior door, that would be right beside a set of further stairs that lead to the basement. However, there is an additional area above that would be 'empty' just above our proposed new door, and new drywall would need to be installed.
How would I install this drywall? Do I have to frame this area before applying the drywall? It is only about a 2 feet high x 4 feet wide area above the proposed door...I'm a relative novice and want to gather informaiton first...
Thanks in advance...
mcvane is offline   Reply With Quote
Old 01-26-2012, 09:15 PM   #2
Rewards Points: 2,210
You will need something to attach the drywall to. A little 2' high wall with a couple of studs would be easy.
Can you post pictures of the area
mae-ling is offline   Reply With Quote
Old 01-26-2012, 11:15 PM   #3
Rewards Points: 83
Here are some pics so you can see how it looks.
installing bamboo on stairs....with crazy angles norcalsurfer1977 Flooring 7 07-24-2012 08:16 PM
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 04:49 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
Installing Hard wood in hallway with stairs basledder Flooring 1 11-03-2008 05:56 PM
