Installing Header For Kitchen Pass Through - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-25-2009, 03:44 PM   #16
Yes it would be a load bearing wall.
mics_54 is offline   Reply With Quote
Old 09-25-2009, 03:51 PM   #17
Registered User
Rewards Points: 5,466
Need one more pic of the ridge support with the diagonal 2x4 on the wall in question. Thanks.
Be safe, Gary
Old 09-25-2009, 04:00 PM   #18
Thank your this is what i thought. Thanks for everyones help now just to figure out if a 2x10 header will be enough.
bpchevyguy is offline   Reply With Quote
Old 09-25-2009, 04:04 PM   #19
you need to know what the design requirements for your local area are. 100# snow load? where are you?
Old 09-25-2009, 04:10 PM   #20
yeah heavy snow load. im in western massachusetts
Old 09-25-2009, 04:48 PM   #21
2x4 wall?
Old 09-25-2009, 04:54 PM   #22
you got it
Old 09-25-2009, 05:33 PM   #23
my supplier said 3 1/2 x 12 would handle the load with 50L/10D load spec. 3" bearing both sides. You could call you local supplier to verify and price a 3.5x12 BC glulam
Old 09-25-2009, 05:47 PM   #24
thank you so much for your help
Old 09-25-2009, 05:55 PM   #25
Is there anything else I could use other than a glulam to make this shorter than the 12"? just cause I have to have the bar height at 48"cause I have a stove on the other side. So it really only leave me with a 2ft 2 inch opening. not a big issue but would like to maximize the opening
Old 09-25-2009, 06:16 PM   #26
Your best bet is to go thru an architect/engineer & have them design support from above
For 26" I wouldn't even open it up
Old 09-25-2009, 07:20 PM   #27
It's obviouly more/expense but you could put the beam in the ceiling rather than benieth it, hang the joists with hangers and your ridge supports on top of the beam.
Old 09-25-2009, 07:38 PM   #28
Registered User
You don't need a glu-lam. You are only carrying ceiling joists. I need a picture of the supports in the attic to see if they are bearing or just put in to hold the ridge board during construction. The snow load does not figure in here, unless you have a broken rafter or two - hence the support picture. To put a beam in the attic would not be difficult, at least from here. What is your rafter span- or- how wide is the house? 28 or 30"? Is the wall centered in that width?
Be safe, Gary
Old 09-25-2009, 08:26 PM   #29
so the width of the house is 24 ft and the wall is centered in the house. (maybe a few inches off approx. 3") . here are the pics hopefully i got what you asked for. Didnt see any broken rafters either. the attic is about 40 ft long also if that factors into anything. also none of the supports are put in with any sort of brackets if that matters
Installing header for kitchen pass through-p1020858.jpg   Installing header for kitchen pass through-p1020855.jpg   Installing header for kitchen pass through-p1020852.jpg   Installing header for kitchen pass through-p1020850.jpg   Installing header for kitchen pass through-p1020851.jpg
Old 09-25-2009, 08:28 PM   #30
There are also cross pieces every three rafters
Expanding Opening & Installing New Header KazzyK Remodeling 4 12-28-2008 10:39 PM
Installing Kitchen Pass-through and header rudy6380 Building & Construction 3 05-28-2008 10:29 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Removing wall, installing header..recommendations? tigerbalm2424 Building & Construction 3 03-25-2008 06:26 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
