Installing Hardi Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 10:47 PM   #1
Installing Hardi board
i am putting down a tile floor around 500 sf .i bought 4x8 sheets of hardi backer an am using modified thinset and using 2 3/8 galvanized ringshank nails 4 the nail gun set to 80 psi. being that it is thinset in with modified would this work in your opinions.?
firreal is offline   Reply With Quote
Old 10-20-2009, 05:44 AM   #2
DIY staff
Rewards Points: 7,174
firreal---------Be careful with such long nails!!!!
If your house was built before 1970 you may have electric conduit under the sub floor.
Check with hardi I believe they suggest 1 1/4 " roofing nails.
With hardi the firmset is a must. I prefer durock myself.-MIKE-
Old 10-21-2009, 05:41 PM   #3
The cheapest unmodified thinset you can find will be fine under the Hardie, next time use Ditra, lighter, faster, easier, better product.
R&D Tile is offline   Reply With Quote
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 10:32 PM
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 4 01-26-2011 09:23 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
