Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-06-2007, 01:28 PM   #1
Installing granite deck
I'm installing a prefab granite countertop that I've cut into several pieces for a jacuzzi tub surround and shower seat in my master bath. I'e cut the pieces so they fit together tightly but am not sure how to glue/cement in place. I've got a 3/4 plywood deck around the tub cut-out and used 1/2" plus 1/4" hardibacker for the shower seat with a piece of Kerdi waterproof membrane over that. What do I use to fix it in place? Is it the same for inside the shower as around the tub? Also, the slab thickness was not uniform. What do I use to raise the thinner pieces slightly to be the same level as the thicker pieces? Thanks for your help.
gskot is offline   Reply With Quote
Old 01-17-2007, 09:32 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
may want to check on the John Bridge tile forum. My buest guess would be to use thinset mortar.
http://www.johnbridge.com/vbulletin/index.php?
Brik is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Decorative Etched Granite Listello csteinke Remodeling 1 06-09-2007 12:54 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
installing granite counter tops dnassif Remodeling 4 07-01-2006 09:37 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
