Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-30-2006, 09:56 PM   #1
installing granite counter tops
for anyone familiar with this, where 3/4 x 3" wooden slats were used for custom tile work that i am replacing, is a plywood sub-surface still needed for granite slabs?
thanks:confused:
dnassif is offline   Reply With Quote
Old 03-31-2006, 06:41 PM   #2
What slats?, on a countertop?:confused:
If you are asking about if wood substrate is needed for a solid surface granite slab on a countertop, the answer is no.
R&D Tile is offline   Reply With Quote
Old 04-01-2006, 12:46 PM   #3
thanks
wife was told that plywood is always required as a subsurface for granite but installer says not so.
i mention the slats because they were built into the original cabinets to support having tile installed. seems to me that they would suffice if support was needed
Old 05-03-2006, 07:46 AM   #4
The installer is correct. If you are dealing with an entire slab of granite it can just be placed directly on the base cabinets.
Krichton is offline   Reply With Quote
Old 07-01-2006, 09:37 AM   #5
I agree with the others with one caveat. If you have an island where the countertop overhang exceeds 9 inches, the consensus of 5 granite counter top companies we talked to was that you should have a substrate that extends out to the edge of the granite or you should install corbels. In our case the overhang was 18 inches so we could have eating space where chairs would fit under the overhang.
HWPipes is offline   Reply With Quote
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
Installing granite deck gskot Remodeling 1 01-17-2007 09:32 PM
granite counter top cutting trifit1 Remodeling 2 02-12-2006 07:56 PM
counter tops feb Remodeling 3 09-03-2005 12:56 AM
