Installing Garage Door ??? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-27-2006, 08:06 PM   #1
Installing garage door ???
My garage door came off track and twisted as a result, I am going to replace the door and the rails, How hard a job is this??
coltsfan is offline   Reply With Quote
Old 07-27-2006, 09:10 PM   #2
What twisted the door or the rails?
The major concern when replacing a garage door is the spring. It is very dangerous if the tension is not properly released.
do a web search on how to replace a garage door. It is easier if you have two people.
redline is offline   Reply With Quote
Old 07-27-2006, 10:22 PM   #3
Both the door and the frame twisted, I got a little carried away trying to get the door up.
Old 07-28-2006, 04:58 AM   #4
If the spring is running parallel to the horizontal portion of the tracks, they are extension springs, and are relatively easy to work on for a DIYer. If the spring is above the door header, parallel to the door, it is a torsion spring, which is not a DIY project, since the springs are very dangerous.
Most Residential door have extension springs.
Pearce Services is offline   Reply With Quote
Old 08-02-2006, 06:21 AM   #5
DIY Garage door
I did it myself several years ago. I used one of those springs you tension with a dril. The scary part was undoing the old spring.
I probably took a big risk, but I just reached around the corner and clipped the cable with some cutters. Hindsight is 20/20 and I absolutely wouldn't recommend this to anyone.
Installing the new door was a breeze. The new opener was a bit more trouble, simply because it was a new installation and there is a serious lack of framing to hang it from.
The directions that came with the door were very good, I think it was a Dalton brand.
indymedic is offline   Reply With Quote
Old 08-11-2006, 01:59 AM   #6
This happened to our roll up door, hubby got it back on track somehow...
Junebug is offline   Reply With Quote
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
Garage door... daveincincy Building & Construction 1 01-17-2006 02:15 PM
