-   -   Installing garage door ??? (http://www.diychatroom.com/f15/installing-garage-door-3218/)
coltsfan 07-27-2006 08:06 PM
My garage door came off track and twisted as a result, I am going to replace the door and the rails, How hard a job is this??
redline 07-27-2006 09:10 PM
What twisted the door or the rails?
The major concern when replacing a garage door is the spring. It is very dangerous if the tension is not properly released.
do a web search on how to replace a garage door. It is easier if you have two people.
:thumbsup:
coltsfan 07-27-2006 10:22 PM
:thumbsup:
Both the door and the frame twisted, I got a little carried away trying to get the door up.:eek:
Pearce Services 07-28-2006 04:58 AM
If the spring is running parallel to the horizontal portion of the tracks, they are extension springs, and are relatively easy to work on for a DIYer. If the spring is above the door header, parallel to the door, it is a torsion spring, which is not a DIY project, since the springs are very dangerous.
Most Residential door have extension springs.
indymedic 08-02-2006 06:21 AM
DIY Garage door
I did it myself several years ago. I used one of those springs you tension with a dril. The scary part was undoing the old spring.
I probably took a big risk, but I just reached around the corner and clipped the cable with some cutters. Hindsight is 20/20 and I absolutely wouldn't recommend this to anyone.
Installing the new door was a breeze. The new opener was a bit more trouble, simply because it was a new installation and there is a serious lack of framing to hang it from.
The directions that came with the door were very good, I think it was a Dalton brand.
Junebug 08-11-2006 01:59 AM
This happened to our roll up door, hubby got it back on track somehow...
