Installing Exterior Wall Vent Cap For Bath Exhaust Fan - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 04:50 PM   #1
Installing exterior wall vent cap for bath exhaust fan
Hi there, I have a question regarding vent cap install on exterior wood siding as seen in the picture. The 6" vent cap is for a new bathroom exhaust fan and made of galvinized steel. The problem is there is no holes round edge of the cap so I can't use screws to secure it onto the wall siding. Is caulking along enough? if is what type of caulk or adhesive would be good for this. Should I nail through the metal flashing to secure it? Thanks.
Ray
Ray_S is offline   Reply With Quote
Old 10-09-2013, 05:34 PM   #2
Rewards Points: 13,260
#1 I would not use a galvanized vent, it's going to rust at some point.
#2 If that's you and the vent your planning on using, stop! You need a siding block first so the vent will sit flat.
Old 10-09-2013, 07:51 PM   #3
Rewards Points: 3,130
Your bathroom fan has a 6-inch vent?? Must be one heck of a bathroom.
Old 10-10-2013, 12:08 AM   #4
Joecaption, thanks for your reply. My questions are about the choice of caulk or adhesives, and how to secure the vent cap without predrilled screw holes. I haven't seen any vent caps with siding block so I would not try that. The picture is from internet and not me, but the install and type of cap are similar.
Old 10-10-2013, 08:51 AM   #5
Rewards Points: 12
Drill your own hole in the flange. Caulk is not enough.
You don't need to use a siding block but you have to make sure you have a good seal around the bottom or wind driven rain will get in. The siding block will make it look better and make aligning the duct work easier. When you mount it directly to the siding, the duct connection is angled downwards.
Dan
djlandkpl is online now   Reply With Quote
Old 10-10-2013, 10:44 PM   #6
Dan, thanks for the advice. I will predrilled holes and screw it on. My siding is T11 type and a little different than that in the picture. In my case the cap will be attached to the wall flat so I am ok without siding block. Thanks again. Ray
Questions on installing a bathroom vent on a Mansard Roof GaryGday Roofing/Siding 3 08-31-2012 11:46 AM
Vent location for bathroom exhaust fan slapdash Remodeling 5 06-26-2012 11:38 AM
Rotate exhaust vent on new propane boiler install? beagle72 HVAC 0 12-09-2011 09:55 AM
2 clothes dryers exhaust vent icandoanything HVAC 4 11-28-2010 03:21 PM
Installing vent in glass block window jasoncw Building & Construction 6 09-27-2009 11:57 AM
