Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-15-2010, 10:35 AM   #1
installing Exterior Door in Breezeway need advise Picture Posted
Hi, This is my first post and I looking for some advice. I have a breezeway that is attached to a brick house. This was added on after house was built and is is sided, not brick. Right now there is a 32" storm/door there. I would like to replace it with an exterior 9 lite door(either steel or fiberglass?). I will probably add a new storm door too later. I have linked some pictures below. The new door will be hinged on the brick side becasue it will be opening inward. The opening right now is 32" x 82 1/2".The is the dimension measuring inside the 2 x 6's(painted white) It is a 2 x 4 wall but the frame which you can see in the picture are 2 x 6's which the storm door is mounted to.
What size door should I install? I've seen some 9 lite exterior doors that are 30"w and also some that are 32"w. I guess i would rather go with the 32".
How do I go about reframing and getting a new rough opeing size(which studs do I take out). I have my ideas, but I want it done the right way so I'm asking for some pro advice. I am pretty good at carpentry but not up on all the terms for framing so a good description or quick sketch would be great!
I hope from my description and pics, someone can help me out. Let me know if you need any other info or pictures and thanks in advance!
http://tinypic.com/view.php?pic=2e1wqx3&s=5
http://tinypic.com/view.php?pic=rr6ut2&s=5
http://tinypic.com/view.php?pic=i6wm7r&s=5
http://tinypic.com/view.php?pic=2py0rxx&s=5
http://tinypic.com/view.php?pic=9sgro8&s=5
http://tinypic.com/view.php?pic=63ziw5&s=5
http://tinypic.com/view.php?pic=10y12kp&s=5
wad2k is offline   Reply With Quote
Need advise installing soffit vent scrupul0us Roofing 11 10-09-2010 08:57 PM
Installing Dishwasher,Need advise on Wiring K.M.G Electrical 20 04-21-2010 03:03 PM
Advise on installing tv display unit bookersbeauty Interior Decorating 2 04-23-2009 05:02 AM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 01:25 PM
Installing my simple railing (picture inside) jelly Carpentry 10 07-21-2008 10:19 AM
