Installing Drip Edge (Cap) Over Barge Board - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 02:28 PM   #1
Rewards Points: 111
Installing Drip Edge (Cap) over Barge Board
Got myself some nice Azek Barge Board to be installed on the front of the house. I have 2 pieces to lay down. 1st - 1x8, 2nd - 1x4 (this goes on top of 1x8 to make a nice look). My house is turned sideways (narrow lot) and the gable end is on the front of house. I have ordered some aluminum drip caps that will wedge under the shingles and extend over both 1 inch edges (2 inch total) of the barge boards. I plan on cutting back the aluminum a bit, so not to cover to much (maybe 1/2 inch) of the 4 inch face of the 2nd board.
Now for the question. When installing the drip edge under the shingles, how to I secure it? There are 3 layers of shingles on this house, so I'm thinking I need to fold back a little and drive a screw or nail through the aluminum to secure it to the roof. Wondering if there are any other suggestions?
Pic attached for visualization. Thanks all!
luvdairish is offline   Reply With Quote
Old 07-04-2010, 06:41 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you have enough shingle overhang?
Tom Struble is offline   Reply With Quote
Old 07-22-2010, 10:13 AM   #3
Rewards Points: 111
There is probably about 3-4 inches shingle overhang. Should I flash the top of the building paper? Is Tyvek Straightflash ok to use for that?
Installing backerboard - replace particle board? salvop Flooring 10 04-29-2011 10:32 PM
FELT: over or under drip edge? Magpie's Friday Roofing/Siding 12 05-08-2009 11:43 PM
Painting Fascia, should I paint the drip edge? PaulR Painting 3 12-19-2008 04:59 PM
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 07:51 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
