Installing Cultured Stone Under Deck - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 09:43 PM   #1
weekend warrior
Smile
installing cultured stone under deck
My deck sits 36in off the ground and I want to install cultured stone under it to appear that stone is holding up the deck.I will be framing it up 16in on center studs and such.What is the best way togo-concrete board,treated ply with wire mesh,need some help here.Plan on doing this myself and could use some advise-thanx
ringers170 is offline   Reply With Quote
Old 05-10-2009, 10:39 AM   #2
Rewards Points: 5,336
With this application, you would need to cap the top of the structure so water did not get into the top of this multilayered material sandwich.
I would use solid block as a substrate, not plywood. While the front is stone, water will still be hitting the back of this through the deck. To go to all the effort with the cultured stone, a masonary substrate will last longer and require much less upkeep.
Ron
Old 05-14-2009, 10:28 PM   #3
weekend warrior
Question
installation
What if I used cement board?I am 28 inches off the ground and from what I have read,I need to install 4 inches off the ground which would leave me 24in install.Any input??
Old 05-15-2009, 05:44 AM   #4
Water will still get through the deck and wet the back of the wall. I would use block.
It's your project, build it the way you want.
Ron
Cultured Stone GGGreen Building & Construction 1 04-25-2009 05:06 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
Repair of a piece of cultured stone that fell off apprentice General DIY Discussions 2 11-26-2007 02:27 PM
