Installing Can Lights In A Drop Ceiling..... - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 08:06 AM   #1
Installing can lights in a drop ceiling.....
I am in the process of finishing my basement and was wondering on how you install can lighting in a drop ceiling. I have been told a few different things; one way is you build some sort of brace just below the I-joist to set the can in so it sits at the grid level. The other way I was told is you simply place the can right on the ceiling tile. This way seems odd as a whole room of cans seems to be a bit heavy for a suspended grid system. Any suggestions??
rwk0930 is offline   Reply With Quote
Old 02-19-2008, 12:59 PM   #2
electrical contractor
Rewards Points: 150
Halo cans are designed to clip directly to the grid, cut the hole in the tile, install the tile then install the can. As you said if there are alot of lights they could get heavy, make sure there are an adequate number of support wires on your ceiling. These grids can hold alot of wieght when done properly, alot of industrial buildings use the grid to hold either lay in flourescents, or surface mounts, and the ballast alone in these fixtures weighs more than a can light.
wire_twister is offline   Reply With Quote
How to convert a drop rod ceiling fan to ceiling mount? Bacardi 151 Electrical 5 01-13-2008 08:04 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
Installing Recessed Lights IdahoBob Electrical 6 08-23-2007 10:03 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
changing drop ceiling to normal ceiling acoustic_bum General DIY Discussions 7 01-16-2007 07:52 AM
