Installing Blinds.... Brackets Need To Go Into Concrete - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 12:53 AM   #1
Installing blinds.... Brackets need to go into concrete
I just had a basement finished, and now need to install/hang up window blinds. The basement windows are cut into the foundation wall, and there's no framing around the inside of the window. They are about 14 inches deep, and I don't want to install the blinds on the ouside, I want them inside, so I'll have to drill the mounting brackets thru the dryall, into the concrete foundation wall behind it.
Is this ok to do, and if so, is a hammer drill the only way to go?
I tried using a masonry bit with my 18-volt drill and it didn't work whatsoever. Here is a picture of one of the windows at rough framing; The white stuff is just a plastic sheet covering the insulation. Its taped right against the foundation;
dtmbizzle is offline   Reply With Quote
Old 04-18-2010, 08:12 AM   #2
DIY staff
Rewards Points: 7,174
A cheap small hammer drill may be in your future. Having a corded hammer drill ( about $29--$39) is worth the expense.
Also the carbide bits--I use bosch any thing cheaper just seem to die to quickly.--Mike--
Old 04-18-2010, 11:12 AM   #3
Thanks Mike. On my way soon to check HD and Lowes for one. I did a little research on the bits, are TAPCON as good as Bosch?
Old 04-18-2010, 12:12 PM   #4
DIY staff
The tapcon bits are fine--The bits last a long time with a small hammer drill--Heat is the big bit killer--Keep a cup of water handy to dip the bit in.
Old 04-21-2010, 07:19 PM   #5
DaBlinds
Be careful with your windows.
Jmccosker is offline   Reply With Quote
Old 05-05-2010, 04:41 PM   #6
I was veeeeeeery careful, and cognizant of the windows. The hammer drill worked perfectly, I was able to put up all 5 sets of blinds in one day. Drilling at that weird angle was difficult, but I was able to get a system down. Hope I never have to do it again tho!
installing shower pan on a concrete floor sv9779 Remodeling 19 03-13-2011 11:03 AM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 08:28 AM
Installing a shower pan--questions on concrete floor RuthL Building & Construction 14 07-21-2009 01:16 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Installing concrete floor in crawl space timchi29 Building & Construction 3 09-16-2008 09:31 PM
