Installing Bigger Basement Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 06:44 PM   #1
Rewards Points: 150
Installing bigger basement window
Getting around to gutting my basement for a remodel.
I have a rather small basement window that i'd like to replace with something bigger to let in a good amount of light , and use for emergency egress ( will not be a bed room down there, but it'll be a den / tv area )
Looking to do this DIY, if i comes down to paying contractor thousands i'll just leave the current window in.
What process required to acomplish this? from what you see in the pictures would i be able to go wider? or just longer top to bottom? both?
any insight would be great.
Thanks!
alecmcmahon is offline   Reply With Quote
Old 11-11-2010, 06:51 PM   #2
how far above grade is the window?
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 11-11-2010, 07:00 PM   #3
Rewards Points: 150
Not much at all, the bottom of the window is only maybe a few inches.
I'd have to dig a pit around it, which i know little about.
Old 11-11-2010, 08:05 PM   #4
DIY staff
Rewards Points: 7,174
That's an older house there----You may not have working perimeter drains--this is needed if you add a window that extend
below the grade--You will need a window well and a drain---(and a perimeter drain for the window drain to go into)
If you have a perimeter drain--go for a taller window---No header issues----Mike---
Old 11-11-2010, 08:10 PM   #5
Rewards Points: 150
I dont have any sort of permiter drain, I think my house was built in the early 50's.
So that being the case it's probably more of a hassle then it's worth then eh?
Old 11-11-2010, 08:35 PM   #6
Anything is possible but you will have to start cutting into that block foundation.
Old 11-12-2010, 06:29 AM   #7
DIY staff
If you don't have any place to drain the water that is going to run into the window well
you will be creating a big nightmare.
If you want to add a longer window that is above grade --you will need to add a header
strong enough to hold up the house above.
Steel flitch plate and another 2x10 might be the easiest.---Mike---
Old 11-12-2010, 07:17 AM   #8
Rewards Points: 150
Thanks mike, looks like we'll be keeping these windows!
The Following User Says Thank You to alecmcmahon For This Useful Post:
oh'mike (11-12-2010)
Old 12-13-2010, 12:00 AM   #9
Rewards Points: 150
Decided to install an interior perimeter drain along the footers of inside my basement.
If I decide to still install a window well and larger window can i pipe the drain from the window well inside the basement and connect it to the perforated pipe under the slab on the inside of the basement , which leads to my sump pump?
Old 12-13-2010, 05:43 PM   #10
Registered User
Rewards Points: 526
Ask your local Building Department on the water.
Finish your basement to minimum safety Code; required window (for the basement) -44" above finish floor, etc...... http://publicecodes.citation.com/ico...9_3_sec010.htm
Gary
Old 12-13-2010, 05:57 PM   #11
Rewards Points: 150
Gary
Im pretty sure around here you are REQURIED an egress window only if there is a bedroom down there, which there will be not. But im considering installing one for the natural light and boost the value of my renovation.
Old 12-13-2010, 08:10 PM   #12
Registered User
Rewards Points: 526
Might want to run that by your local B.D. as it has been required for many years, depends on which year's Code your finish basement will be inspected under fot the paper trail for you H.O. Insurance carrier and adding it as habitable floor space when selling.
Gary
Installing horizontal blinds with window above godma Interior Decorating 2 09-30-2010 03:18 PM
Replacing a 20" x 32" basement window Fox Remodeling 2 06-12-2010 12:19 PM
framing basement window ant1929 Remodeling 3 01-15-2010 02:53 PM
basement window replacement ponch37300 Building & Construction 3 08-12-2008 03:58 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
