Installing A Bathroom Fan In A Cold Climate - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-31-2010, 11:26 AM   #1
Newly Retired
tuchodi's Avatar
I am adding an Ensuite Bathroom to the Master Bedroom and want to know for a colder climate (Central BC Canada Temp range from -10 to -30) the best way and where to install the bathroom fan Exhaust Vent. Should I go straight up through the roof or go out sideways and vent throught the end gabble which is about a 20' run. Also what kind of a cap is the best for the vent outside to reduce the possability of Ice build up.
tuchodi is offline   Reply With Quote
Old 01-31-2010, 11:40 AM   #2
Too Short? Cut it Again!
I guess you could do either but I would pick the shortest run. 20' is quite a long way so make sure the fan you get is going to move enough air through that run or things could just sit in the duct.
If you go through the roof, they make a roof cap that sits parallel to the roof. You just lift off shingles, flash it, replace the shingles.
Old 01-31-2010, 12:07 PM   #3
Newly Retired
tuchodi's Avatar
I have a Metal Roof so does that make a differance except in the way I will have to seal the cap flashing to the roof. I was mostly worried about the moisture venting and if there would be a build up of ice or a freezing problem going straight up. Straight up would be the easiest. Do I also need to insulate the short run of pipe that will be going throught the attic?
Old 01-31-2010, 12:38 PM   #4
Could be a problem given the temps you mention. Wait and see what others post. Does the attic drop below freezing too?
Old 01-31-2010, 12:42 PM   #5
Newly Retired
tuchodi's Avatar
Yes the attic would be what ever the Temp is outside.
Old 01-31-2010, 04:32 PM   #6
Registered User
Rewards Points: 5,266
20' is a fairly short run, considering the other option. http://www.efi.org/factoids/bathroom_sizing.html
I would insulate the metal fan box, the ducting (solid smooth metal), and the gable area directly around the duct/hood connection. Use at least the R-value required for ducting, if not double. Start with a 22* elbow at the fan, run up high enough to another elbow, then pitch down to the hood in the remaining length to drain the condensation out at the gable. Foil tape all seams, even the individual elbow's. Support ducting every 4', no flex pipe: http://www.pse.com/SiteCollectionDoc...S_Moisture.pdf Be aware not to over-size motor, drawing gas appliance's exhaust for make-up air. Make sure holes to drain condensate at hood are set away from house and not over wood that could rot. Use multiple doors vinyl hood, not one piece metal that could freeze-up easier.
Be safe, Gary
Old 01-31-2010, 10:13 PM   #7
Newly Retired
tuchodi's Avatar
Thanks Gary:
Great points and now it doesn't seam to be such a problem with the 20' run.
Vent Bath Exhaust to Cold Air Return? brandon272 HVAC 12 03-28-2011 06:11 AM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Question about installing tile in my downstairs bathroom UpComingBuilder Flooring 1 05-21-2009 08:17 AM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
