Installing Bathroom Fan - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 01:10 PM   #1
So I want to install a bathroom fan in my already finished basement bathroom. The only thing is that the floor joists are running perpendicular to the shortest route (about 4' of run). Meaning I'll have to drill 4-1/8" diamater through my 2x8 floor joists.
Coincidentally, the upstairs bathroom is directly above my downstairs bathrrom as well.
Would there be any problem drilling this size hole in about 4-5' worth of floor joists?
bates is offline   Reply With Quote
Old 07-24-2012, 01:48 PM   #2
How will I vent it if I'm not able to drill through these joists? The only other route is about 15' and this runs parallel to the joists.
Old 07-24-2012, 05:37 PM   #3
Rewards Points: 3,130
Don't even think about drilling a hole that size in 2x8 joists. Run it the long way, and don't use cheap flex ducting. Maybe consider a higher capacity fan.
Old 07-26-2012, 10:59 AM   #4
Rewards Points: 2,202
Can you run it below the joists and box it in using a bulkhead?
Or relocate it , it does not have to be center of the bathroom.
I have put them in the wall in the corner above the shower head as well.
mae-ling is offline   Reply With Quote
Old 07-26-2012, 12:24 PM   #5
Why do you have two separate threads going about this problem??
The Following User Says Thank You to md2lgyk For This Useful Post:
mae-ling (07-26-2012)
Installing a Toilet on a new tile bathroom floor saltrl Introductions 2 06-21-2011 09:12 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
installing a bathroom heater (Step1) pstock Electrical 2 09-21-2009 05:05 PM
Running into difficulties installing bathroom mirror (pics of the nightmare incl.!) joeyboy General DIY Discussions 18 08-10-2007 11:04 AM
