Installed A New Styrene Tub, Getting Ready To Tile Above. Durock, Or Hardibacker? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 04:12 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Installed a new Styrene tub, getting ready to tile above. Durock, or hardibacker?
Going to use roofing felt vapor barrier, then CBU,then tile. With all the different types of backerboards out there, I'm wondering which I should use. Wonderboard, Durock, hardibacker? If it makes a difference, the backer board will mate up with drywall where the common wall goes from wet area to non wet area. I'd rather keep the cost as low as I can while still doing the job right.
J187 is offline   Reply With Quote
Old 03-30-2009, 05:18 PM   #2
Remodeling Contractor
any are okay. Still need to seal the seams and apply waterproofing like Redgard over it.
Old 03-30-2009, 05:26 PM   #3
Do not use Redgard if you install a vapor barrier behind the cementboard, one or the other, not both, I would use cementboard and Redgard
Or, for tub surrounds, Wedi Panel or DensShield, both products work well too.
R&D Tile is offline   Reply With Quote
Old 03-31-2009, 07:49 AM   #4
J187's Avatar
Rewards Points: 516
Thanks guys... I hadn't mentioned waterproofing because I had read not to do it if I was going with a vapor barrier, as you suggest I shouldn't... but I also had read that the barrier was better than waterproofing, I'm glad to see you suggest hardi and guard, that was kinda the way I wanted to do it.
resetting toilet after new tile installed shotdown Plumbing 10 07-01-2009 10:09 AM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
How Do I Repair an Improperly Installed Shower Floor MartinGale Flooring 3 11-26-2007 08:36 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 12:27 PM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 02:26 PM
