Installed Granite W/ Top Mount Sink - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-01-2008, 01:09 AM   #1
Installed Granite w/ Top Mount Sink
Well, this was my first install of a Granite Top. I never did it before but I think it came out nice...
I caulked around the rim of the sink with 100% clear silicone. Does it look good or should I redo the silicone? I know it will be a mess to remove....
JackOfAllTrades is offline   Reply With Quote
Old 02-01-2008, 09:07 AM   #2
the silicone looks alittle thick all you need is a small bead around the sink nothing just to prevent water from leaking through. it not like there is going to be major water spraying on it or anything. if you put a small bead of silicon around the sink and then run your finger around it that small amount that is left will do fine. but over all it looks real good if you dont feel like messing with it anymore.
PSHome is offline   Reply With Quote
Old 02-01-2008, 09:12 AM   #3
Thanks. So, if it was your sink/home, would you redo it and place a smaller bead?
Old 02-01-2008, 09:20 AM   #4
that all depends on how hard it would be to take off. LOL If I caulked it and dint like it but it would take me more time to remove it then it did installing it then i would live with it. but if it comes off easier than i put it on then i would take it off and redo it. Caulking it a pain for me, I dont like it and it dont like me. So i try not to mess with it. I put it on make it look some what good then leave it.
Old 02-01-2008, 12:51 PM   #5
Just run a blade to cut the excess. Peel away. The remainder that stays between the sink and the top will seal it.
redline is offline   Reply With Quote
Old 02-02-2008, 07:30 AM   #6
It's not what I think. If you have to ask, it'll bug you forever. Nice granite.
tkle is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Outlet installed under sink, under cold water valve? akinito Electrical 3 01-10-2008 08:55 PM
Installed bathroom sink, smell now HuskySkull Plumbing 1 07-20-2007 04:12 PM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 10:27 AM
Decorative Etched Granite Listello csteinke Remodeling 1 06-08-2007 11:54 PM
