Install A Sliding Glass Door With Limited Header Space - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 01:59 PM   #1
Install a Sliding Glass Door with Limited Header space
Hello everyone and thanks in advance for your advice.
I have a contractor friend who is going to assist me with installing this sliding glass door in the back of my house. However, we have encountered an issue that he hasn't seen before and I was wondering if someone on here has. The main issue is that my ceilings are only 7'6" ceilings so after measuring everything out we only have enough room for a 7" header to support the weight of the roof. He says that normally you would want a 12" header for such a task.
My question here is do you know if we should use metal or wood or what as the support header for this installation. For those wanting the actual measurements, we have a 7" header that will span 6' and it will support a 30' long roof truss.
What can I safely use as a 7" header keep in mind I live in the Indianapolis area, so the roof will at times be bearing snow loads.
Thanks for your help.
aamcleve is offline   Reply With Quote
Old 03-26-2013, 02:47 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
find out from you local building department what the ground snow load is for your area. what is the pitch of your roof? 5/12, 6/12, 12/12? is the 7" the space from the bottom of the top plate to the top of the door frame?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-26-2013, 02:52 PM   #3
roof pitch is 4/12, ground snow load for this area is 20PSF, and yes the measurement is from the bottom of the top plate to the door frame.
Thanks for the speedy response.
Old 03-26-2013, 02:58 PM   #4
GBrackins's Avatar
2x4 or 2x6 exterior wall?
Gary
Old 03-26-2013, 03:03 PM   #5
It is a 2x4
Old 03-26-2013, 03:04 PM   #6
GBrackins's Avatar
ouch!
Gary
Old 03-26-2013, 03:08 PM   #7
Have you used those LVL boards? I was wondering what your thoughts were on a solution like that. I found a LVL board that is 7 1/4" at Menards, I wonder what would happen if I stuck two of them together.
Old 03-26-2013, 03:29 PM   #8
GBrackins's Avatar
based upon a 6' span with a 15' tributary load (1/2 of 30' truss span) with 30 pounds per square foot total load (20 pounds per square foot live load + 10 pounds per square foot dead load) I come up with the following options:
two-ply 1-3/4"x5-1/2" LVL. would have about an 1/8" of deflection. not sure if you local lumber yard stocks those or not.
a 3 ply 2x6 doug-fir #2 would work as well, of course the inner ply would be sticking to the inside of the wall. join together with construction adhesive and 16d common nails at 12" center to center.
a 2 ply 2x8 doug-fir #2 (ripped to 7") will work. install 1/2" plywood in between the members so that the width of the header is 3-1/2". would give you around a 1/16" deflection. now if you have a permit and will be having inspections the building official may require engineering for the ripped 2x8's since they are not nominal depth.
here is a link to the prescriptive code requirements based upon the 2009 International Residential Code for headers in an exterior wall. http://publicecodes.cyberregs.com/ic...?bu2=undefined
good luck!
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
aamcleve (03-26-2013)
Old 03-26-2013, 03:30 PM   #9
GBrackins's Avatar
if a 2 ply 1-3/4x5-1/2 will work a 2 ply 1-3/4x7-1/4 will work. just not suppose to rip LVL without approval of an engineer or manufacturer
Gary
Old 03-26-2013, 03:34 PM   #10
Rewards Points: 13,300
Think it would help to use a 1/2 steel plate instead of the 1/2 plywood?
GBrackins (03-26-2013)
Old 03-26-2013, 03:41 PM   #11
GBrackins's Avatar
it would, but I'm not a big fan of flitch beams, flitches take time to put together. if I need to bring steel into the mix I'd just as soon use either a W or S shaped steel beam. And with all of the engineered wood options out there you can usually find something off the shelf that works.
Gary
Old 03-26-2013, 03:45 PM   #12
Thank you very much GBrackins. I assume experience allows you to spurt out this information, I only hope to someday have a quarter of that type of building knowledge in my head.
Old 03-26-2013, 03:55 PM   #13
GBrackins's Avatar
you're welcomed. I'd go with the LVL if I was doing this project.
Gary
Windows on Wash (03-26-2013)
Old 03-26-2013, 04:40 PM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,940
+1
They aren't that expensive either as their popularity has expanded.
Old 03-26-2013, 04:54 PM   #15
Rewards Points: 528
he also could cut out the top plates to give him more room with the trusses bearing on the header.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 11:39 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Replacing header over sliding glass doors bluefitness Remodeling 11 11-04-2008 09:04 PM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 09:49 PM
