Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-20-2013, 09:35 PM   #1
Install Load Bearing
Hi, this is my first help post.
I want to open up wall between kitchen and living.
I need to install the bearing.
I've watched many many youtube videos and I did not get any detailed info out of it.
Wall to wall is about 19ft
What calculation do i need?
What permits.
What and where do I begin?
I want to do it legally meet regulation.
As Holmes On Homes Say "Do it right the first time"
nauttboy is offline   Reply With Quote
Old 03-20-2013, 09:43 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
so..... what are you trying to do exactly. you have a open concept house and you want to close the space off with a wall.. just stud it in.. if the beam is carrying the weight above the wall will simply give a nailing base for drywall
woodworkbykirk is offline   Reply With Quote
Old 03-20-2013, 09:46 PM   #3
Opposite to what you are thinking.
I did mentioned, I want to open up walls.
Yes, have open concepts.
I have small house, with this open, i have more space.
left picture before(now) right picture (after) later.
Old 03-22-2013, 07:00 PM   #4
GBrackins's Avatar
the size of the beam is based upon the loads it must support, the type of beam being used, and the span of the beam. This is not a simple matter as a mistake made can be costly. Structural design is not something a person should come to an internet forum to obtain.
To properly assess the path of gravity loads (as well as lateral loads) a person needs to visit the structure and observe for themselves the existing construction. I would recommend hiring a local professional engineer to come to your home and evaluate your needs and prepare construction drawings.
Typically performing structural work requires a building permit and meeting the local building codes. A call to your building department will determine that. An engineer can prepare the necessary drawings and specifications so that you do the job correctly the first time .....
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Do you think this wall is load bearing? rchickering Remodeling 17 11-21-2011 06:35 PM
Determining a Load Bearing Wall (Pic Included) Evil Scotsman General Discussion 18 03-02-2011 03:46 PM
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 06:27 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 05:25 PM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 07:19 PM
