Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-16-2012, 02:03 PM   #1
install laminate countertop
I installed my own cabinets they have plastic on each corner with a whole. I am guess this is where you put the screw to attach the countertop? What screws should I use? Can I use drywall screws? Any precautions I should be aware of and recommendations before securing it down. Thank you.. This is for a laminate countertop
ryanb4614 is online now   Reply With Quote
Old 02-16-2012, 02:08 PM   #2
Do not use drywall screws. They make large head screws with special threads to hold in the partical board for this job.
Just make sure there not to long or they will poke through the top.
Old 02-16-2012, 10:41 PM   #3
Dont forget build up strips.
Total Tool is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Cutting Laminate Countertop From Lowes ryanb4614 Building & Construction 3 12-29-2011 05:26 PM
Laminate? Install cabinets before? MikeVila Flooring 15 11-04-2010 10:58 PM
Countertop - Epoxy Granite over Laminate sdrachel Remodeling 1 09-19-2009 07:15 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 08:07 AM
