-   -   Install glass tile on wood stud pole (for support beam) (http://www.diychatroom.com/f15/install-glass-tile-wood-stud-pole-support-beam-47122/)
chatelain 06-20-2009 05:53 PM
I'm new to installing glass tile. I have a 7 foot pole made up of 4 wood studs that supports a support beam. We've decided to use 1" glass tiles to cover it. Just wondering what kind of base we need for this. Is thinset enough to fill in the cracks made between each stud? This pole is close to the middle of the basement so there is no need for water protection. Is there something we need to make sure the mortar (or thinset) doesn't soak into the stud?
Paragon 06-21-2009 10:45 PM
DO you by chance have a picture of the columns that you are looking to tile?
I envision it a certain way and if it is that way then I would cover it with a drywall first. This is going to be the most frugal way of doing this project but it depends on the individual job. You might be better off covering it with backer board but then again it just depends on the job. I would not just go with the tiles right over the studs as you don't want any voids under those glass tiles because it will transmit right through and be visible as a finished product. Also tiling with glass is a little different than tiling with ceramic as you can apply the adhesive with the notched side of a trowel but you want to smooth it out with the straight edge of the trowel before you put the glass tiles in place. the reason you do this is because if you apply the adhesive with the notched side the grooves will show through and be visible through the tiles.
Take a pic if you get a chance and we can go from there!
Good luck and be safe!
