Install Exterior Lights - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 12:23 AM   #1
install exterior lights
how do i install a 7 inch exterior light on hardiplank siding
eddieo is offline   Reply With Quote
Old 11-13-2012, 12:34 AM   #2
Rewards Points: 13,300
Got a picture of the light fixture?
Going to be a challange with Hardee siding.
Going to need to add a siding block.
I make my own out of vinyl lumber.
The siding block lets you mount the lamp so it sits level.
Old 11-20-2012, 11:34 PM   #3
JuzRick's Avatar
Its not a challenge at all.. if your not a newbie. NOT arguing against the other guy either. I done install them to often. Once you get the method its nothing to it! I will give this advice thou; use a whole saw cutter to properly/accurately cut the hole evenly. Then use a electric nm work repair box(if the wall your installing on is closed in on both exterior side of the wall..if you already have the wire already set for the new light).
JuzRick is offline   Reply With Quote
Looking for help on how to install recessed soffit. Snoopy_ Roofing/Siding 2 09-04-2012 04:45 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 06:46 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 01:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
