Install Door In Drywalled Opening? - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 06:08 PM   #1
Install door in drywalled opening?
I am trying to add a door where there is already a drywalled hallway opening. The opening does not go to the ceiling, it is in the shape of a door so there may have been a door there in the past (60's home). Do I just strip back the drywall a bit and go for it to install a prehung door? How should I start out?
BeMurda is offline   Reply With Quote
Old 04-10-2012, 07:18 PM   #2
Rewards Points: 6,652
That is correct. Once you remove the gypsum from within the opening, you can get the rough opening size. Or just measure now, and figure probably 1/2" wallboard if a newer home, anything built this century could have 5/8ths on the walls. Anything early century that is Plaster & Lathe or Rock-Lathe could be 1".
Old 05-03-2012, 02:47 PM   #3
Thanks. I have a photo here, looking for a bit more guidance. The house is a 1963 Canadian bungalow.
This is entering into our kitchen which is recently redone, so I absolutely do not want to remove more drywall than necessary. I want to minimize patchwork. In the photo pictured, where must I actually remove gypsum?
I have also included measurements. what size of prehung door do you think would be best, and does anyone foresee any issues with these measurements for the opening?
Old 05-03-2012, 06:16 PM   #4
Rewards Points: 13,694
http://www.sawkerfs.com/Rough_Openings_For_Doors.html
Old 05-03-2012, 06:22 PM   #5
How deep is that landing? It will look odd, having a door then a door in a area that normally you would not for a airlock.
Old 05-03-2012, 07:55 PM   #6
Rewards Points: 2,212
I would use a 32" BY 80" door, You may need to cut it down for width (whole nother topic). you should be able to use 2 & 1/4" casing around it. You will need to add to the jamb or make a custom one.
Now having said that usually you can not have a door at the top of the steps, you need a minimum of 3'.
I am guessing there was no door there before.
mae-ling is offline   Reply With Quote
Old 05-03-2012, 08:02 PM   #7
Rewards Points: 150
Mae-Ling nailed it, those steps will cause some real "issues".
Jeeps is offline   Reply With Quote
Old 05-04-2012, 11:48 AM   #8
Hi all,
What issues will the steps cause exactly? I don't get it. I spoke with a person at home depot and he suggested I would not have to remove the drywall. We figured it would open inwards towards the wall on the right of the photo. Is he out to lunch? I bought a 32" by 80" prehung door.
Old 05-04-2012, 12:23 PM   #9
Originally Posted by BeMurda View Post
Hi all,
One problem, is that it is a safety issue. Second you spoke with some idiot in a Orange cape at Home Depot.
Old 05-04-2012, 12:46 PM   #10
Fair enough, haha... The safety issue, if it opens into the room and not onto the stairs, doesn't seem major though. Unless I am missing something I can live with that arrangement. Where on the photo would I actually have to strip back the drywall?
Old 05-04-2012, 01:23 PM   #11
Experienced
Jackofall1's Avatar
I believe the 36" requirement if for exterior doors, interior doors at the top of stairs isn't a problem from what I know, have seen them many times.
IRC
R311.3 Floors and landings at exterior doors. There shall be a landing or floor on each side of each exterior door. The width of each landing shall not be less than the door served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel. Exterior landings shall be permitted to have a slope not to exceed 1/4 unit vertical in 12 units horizontal (2-percent).
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
mae-ling (05-07-2012)
Old 05-07-2012, 01:52 PM   #12
Thanks. Do I just need to remove the drywall for the 5 inch depth space where the door will be placed?
Old 05-07-2012, 02:35 PM   #13
Experienced
Jackofall1's Avatar
Yes absolutely, you will want to do that for a couple of reasons, to allow a more secure install and to gain the added width back from the drywall.
You will be putting case mouldings around the door anyway so removal of the DW is no big deal. There should be a metal corner bead on each corner, just to let you know, when you start removing the DW.
Mark
Old 05-09-2012, 02:21 AM   #14
It is right, you can install a door there but if it do not creates unnecessary problems. Before do this i think you sholud take advice from any shutters and doors services providers. They will suggest you a right option.
Shutters
payalmittalmay is offline   Reply With Quote
Getting a furnace through a narrow opening? Sowchoy HVAC 3 02-15-2010 07:55 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Opening for attic stairs sk8z Remodeling 16 03-17-2008 12:52 PM
Hanging doors on drywalled and finished opening dk_99 Building & Construction 9 12-31-2007 09:34 AM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
