Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-17-2007, 06:16 PM   #1
Cool
Install a dishwasher in an existing kitchen cabinet
I finally snagged a dishwasher and we need to know how to go about removing the existing kitchen cabinet. I can post pictures later if needed. The cabinets are site built and there are no seams between the individual cabinets. It has a drawer and a middle and lower shelf.
Any advice or 'thou shalt nots' will be appreciated.
[Water supply and electrical are no problem.]
shapeshifter is offline   Reply With Quote
Old 10-17-2007, 06:57 PM   #2
Remodeler
MinConst's Avatar
Well, basically you need to cut out a 24" section. You say they are built in. Is that last year or 40 years ago? With no joints you will need to make one or two pretty precise cuts depending on if your DW placement is in between cabs or at the end. You can also cut the opening an inch larger and cover the cuts with corner moulding. Depending on the top is fastened could present another problem. Many tops were nailed screwed into the cabs from the top. If this is the case you will either have to break away the cabs (bad idea) or cut the fasteners with a sawzall.
Once you have the opening it jut a matter of running the electric and plumbing. You said no problem there.
Don't forget to support the counter top if this DW is going on the end.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 10-17-2007, 07:32 PM   #3
Question
I really appreciate your feed-back. Actually the house is 24 years old. The D/W will be sitting between two cabinets so I hope the counter top won't be an issue. Anyway, it's a cheezy old formica top and will be replaced next year. And I'm thinking the sawzall will be what we have to use.
I would expect we would 1st remove the drawer from the cabinet, draw our horizontal lines on the shelves and vertical lines cabinet face [minding the bubble, of course.] Then I would expect we would 1st remove the middle shelf. Since the shelf is one long piece that extends into the next cabinet, the remainder will have to be braced some how. Will it be enough to just add a cleat to the back side of the front of the cabinet beneath the shelf? All it holds is some bake ware, no great amount of weight.
I would expect that actually removing the cabinet face would be next and the lower shelf, and kickspace last.
Old 10-17-2007, 09:06 PM   #4
Remodeler
MinConst's Avatar
You will want to fasten this shelf support in the front and rear. You can screw right through the front by counter sinking the screws a bit and filling with wood putty, if you want to paint this after. Or you could use some small angle irons with short screws from the back of the front panel.
Sounds like a plan. Just go slow, try not to break anything that has to stay. Also you can cut the fronts a bit over if you have a sander and then sand to the line to make a nice clean line.
My comments are in red. I had to add this to make the forum software happy.
Old 10-18-2007, 10:27 AM   #5
Question
This question is probably a little late to ask but when the dishwasher is described as 24" wide, is that the part that fits into the cabinet, or the part that you see from the front? [We are purchasing the dishwasher 2nd hand, it was a deal we could not refuse!]
Thanks.
Old 10-18-2007, 04:50 PM   #6
Mod / ArchiBuilder
Cole's Avatar
On a job next week, we are retrofitting a dishwasher into existing lower cabinets.
I will post pics during and when we are done!
Cole is offline   Reply With Quote
Old 10-18-2007, 05:01 PM   #7
Wow, that would be great! If possible, can we see before-and-after pix?
Old 10-18-2007, 05:08 PM   #8
Mod / ArchiBuilder
Cole's Avatar
Sure can, I will take before and after photos.
Old 10-18-2007, 06:46 PM   #9
Talking
I just noticed, you guys are just up the street from me, IH 35, that is
Old 03-16-2008, 02:05 PM   #10
Knucklez's Avatar
where did you post the before/after pics?
Knucklez is offline   Reply With Quote
Replacing Kitchen Cabinet Door Hinges Eric_ht Carpentry 4 04-18-2008 08:42 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
Limited Kitchen Remodel - Cabinet Refinishing Sarge Carpentry 6 07-19-2007 11:38 AM
Kitchen Cabinet Replacement jimgepner General Discussion 6 10-16-2006 04:45 AM
Need recommendation for type of kitchen cabinet paint MBScott Painting 10 09-08-2006 10:12 AM
