-   -   Install a dishwasher in an existing kitchen cabinet (http://www.diychatroom.com/f15/install-dishwasher-existing-kitchen-cabinet-12488/)
shapeshifter 10-17-2007 05:16 PM
I finally snagged a dishwasher and we need to know how to go about removing the existing kitchen cabinet. I can post pictures later if needed. The cabinets are site built and there are no seams between the individual cabinets. It has a drawer and a middle and lower shelf.
Any advice or 'thou shalt nots' will be appreciated.
[Water supply and electrical are no problem.]
MinConst 10-17-2007 05:57 PM
Well, basically you need to cut out a 24" section. You say they are built in. Is that last year or 40 years ago? With no joints you will need to make one or two pretty precise cuts depending on if your DW placement is in between cabs or at the end. You can also cut the opening an inch larger and cover the cuts with corner moulding. Depending on the top is fastened could present another problem. Many tops were nailed screwed into the cabs from the top. If this is the case you will either have to break away the cabs (bad idea) or cut the fasteners with a sawzall.
Once you have the opening it jut a matter of running the electric and plumbing. You said no problem there.
Don't forget to support the counter top if this DW is going on the end.
shapeshifter 10-17-2007 06:32 PM
I really appreciate your feed-back. Actually the house is 24 years old. The D/W will be sitting between two cabinets so I hope the counter top won't be an issue. Anyway, it's a cheezy old formica top and will be replaced next year. And I'm thinking the sawzall will be what we have to use.
I would expect we would 1st remove the drawer from the cabinet, draw our horizontal lines on the shelves and vertical lines cabinet face [minding the bubble, of course.] Then I would expect we would 1st remove the middle shelf. Since the shelf is one long piece that extends into the next cabinet, the remainder will have to be braced some how. Will it be enough to just add a cleat to the back side of the front of the cabinet beneath the shelf? All it holds is some bake ware, no great amount of weight.
I would expect that actually removing the cabinet face would be next and the lower shelf, and kickspace last.
MinConst 10-17-2007 08:06 PM
You will want to fasten this shelf support in the front and rear. You can screw right through the front by counter sinking the screws a bit and filling with wood putty, if you want to paint this after. Or you could use some small angle irons with short screws from the back of the front panel.
Sounds like a plan. Just go slow, try not to break anything that has to stay. Also you can cut the fronts a bit over if you have a sander and then sand to the line to make a nice clean line.
My comments are in red. I had to add this to make the forum software happy.
shapeshifter 10-18-2007 09:27 AM
This question is probably a little late to ask but when the dishwasher is described as 24" wide, is that the part that fits into the cabinet, or the part that you see from the front? [We are purchasing the dishwasher 2nd hand, it was a deal we could not refuse!]
Thanks.
Cole 10-18-2007 03:50 PM
On a job next week, we are retrofitting a dishwasher into existing lower cabinets.
I will post pics during and when we are done!
shapeshifter 10-18-2007 04:01 PM
Wow, that would be great! If possible, can we see before-and-after pix?
Cole 10-18-2007 04:08 PM
Sure can, I will take before and after photos.
shapeshifter 10-18-2007 05:46 PM
I just noticed, you guys are just up the street from me, IH 35, that is :laughing:
Knucklez 03-16-2008 01:05 PM
4 Attachment(s)
where did you post the before/after pics?
