Install Closet Door Over Drywall - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 09:41 PM   #1
Install closet door over drywall
I have a closet opening that is finished with drywall. I want to install a prehung door in this opening. Should I remove the existing drywall from the closet opening, or just install the door in the existing drywall in the opening. I am afraid if I do not install the prehung door over the bare wood frame, the door will not be stable against the drywall that is currently there. The shims may sink into the drywall instead of sitting flush against the wood.
Fixitdude is offline   Reply With Quote
Old 09-06-2012, 09:48 PM   #2
Rewards Points: 13,274
The rough opening is going to have to be 2" bigger then the door size and 1" higher then the jamb so most likly it's going to have to go. It may even need to be reframed. Just going to have to measure and see.
Old 09-06-2012, 09:57 PM   #3
AHH, SPANS!!!
Rewards Points: 1,166
The size of the door as compared to the current opening size will determine if the door will fit or not. If the opening is a standard door sized opening with drywall then a standard door size will not fit, the drywall inside of the jamb and corner bead will have to be removed.. If the door is smaller than the current opening size, the opening will need to be reduced down in size to fit the door.
hand drive is offline   Reply With Quote
Old 09-06-2012, 10:15 PM   #4
DIY staff
Rewards Points: 7,174
Member has a drywalled door opening---wants to know if installing a prehung will be stable with drywall under the jambs,
Either way will work--the shims aren't going to sink into the drywall.
I would prefer removing the drywall first---because you will gain an inch in width----wider doors are better than narrower ones----
Also--the tin corner bead might add to the thickness of the wall---making trim install a tougher job----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
hand drive (09-06-2012), mae-ling (09-07-2012)
Cement Board or Drywall or Both Calvo Remodeling 6 03-07-2012 12:24 PM
Install and drywall around laundry/washer box cmyk Plumbing 8 06-20-2011 09:41 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 03:10 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
