Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-10-2010, 07:51 PM   #1
install ceiling fan in a suspended metal stud ceiling?
hey folks, i hope we can find a suitable solution for my problem.
I really want to install a ceiling fan in my loft apartment since the summer heat is pretty unbearable. I went out and purchased a Westinghouse safe-t-brace, read up on the information, and thought it would be a snap to secure this to the wooden rafters.
However, after removing the existing light fixture and peeking in the ceiling, I have now discovered that I actually have a suspended ceiling! The wooden rafters are about a foot above the finished drywall ceiling, and the sheetrock is supported by 2.5" metal framework. I dont yet see how the metal studs are being supported (looking through a small 5" hole).
Can I still safely install a ceiling fan, and if so, how??
I have thought about the possibility of using 2x6's attached to the rafters and extending to the finished ceiling height, or somehow laying the boards across the metal studs, but am very concerned about the stability. To do this i would have to open up the drywall a lot more. Also, the ideal position i would like to have the fixture is right up against one of the metal studs.
What can I do about this? any ideas? thanks
amp3d is offline   Reply With Quote
Old 09-10-2010, 08:26 PM   #2
Xtreme DIY'r
Is this an Apt you are renting ?
If so you should not be touching any electric
Old 09-10-2010, 08:55 PM   #3
yes but my situation is such that the owner doesn't mind whatever modifications I make, so long as it is safe and not detrimental. We are also on the understanding that i may be living here for 2-3 years, or until I can make enough money to move on with the next stage of my life. So DIY work is a go! I have already knocked down a wall to merge the living room with a bedroom to form a semi-studio setup, laid down laminate flooring, and will be building a counter/bar soon. Now I am looking to solve the heat/air circulation problem during the summers by use of a ceiling fan.
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
Dropped Ceiling attached to metal joist cadmonkey Building & Construction 10 06-18-2010 11:26 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 01:05 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Ceiling fan suspended ceiling bdalekid Electrical 15 03-17-2007 12:03 PM
