Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-28-2012, 09:33 PM   #1
Install bathroom plumbing,
How to cut plumbing hole through a 6" concrete wall, in a basement to attach to sewer line?
Judy50 is offline   Reply With Quote
Old 04-28-2012, 10:52 PM   #2
Core drill would be the best way to get a round hole. HD or any rental place should have one.
http://www.contractorsdirect.com/MK-...ill-Rig-162675
It can also be done with a series of holes close together with an impast drill and just knock out the plug but it makes for one messy hole and will blow out the concrete where the drill comes through.
Ravenworks (04-29-2012)
Old 04-28-2012, 11:19 PM   #3
is this a poured wall or a block wall?
itsnotrequired is offline   Reply With Quote
Old 04-29-2012, 08:42 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You can also get bid(s) from concrete coring companies. The costs are also less if you agree to break-up and dispose of any debris for them.
- Build Well -
Old 04-29-2012, 09:18 AM   #5
Ravenworks's Avatar
You will also have to sleeve the pipe that is going to come through the wall with another pipe,but as the others said core it,that is the surest way I know how to do it.
Ravenworks is offline   Reply With Quote
The Bathroom Remodel that just kept growing... (Question 2 of many - Plumbing Vents) gpsmith Kitchen & Bath Remodeling 1 05-30-2011 08:37 AM
Plumbing bathroom limited vertical space osmotik Plumbing 5 03-31-2011 01:13 PM
Bathroom plumbing question btmtat Plumbing 1 02-20-2011 10:42 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 01:17 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
