Install Baseboard Over/around Existing Trim Of Bathroom Vanity? - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2011, 12:03 AM   #1
Install baseboard over/around existing trim of bathroom vanity?
I am replacing old 2" baseboard molding in my bathroom. The new baseboard is 3-1/4" and thicker / less flexible.
My vanity cabinet already has some 1" flat molding running vertical between the cabinet and the back wall - problem is that this flat molding runs all the way to the floor (Photo 1). I don't see how cutting the flat molding is an option (seems like it would ruin the wall/vanity).
It will look quite tacky if there is no baseboard on side of vanity - slight gaps from flooring make it look unfinished (you can't really tell this from the close up photo).
Do I install the new baseboard over the top of the vertical molding? See photo 2, this makes the new baseboard stick out about 1/4". How do I fill in the 1/4" gap, about 19" long? Seems a bit much to caulk.
Or, do I use 0-degree cuts on both walls surrounding the 1" trim and just live with the gap? See photo 3
Suggestions / ideas appreciated!
Install baseboard over/around existing trim of bathroom vanity?-corner.jpg   Install baseboard over/around existing trim of bathroom vanity?-gap.jpg   Install baseboard over/around existing trim of bathroom vanity?-flush.jpg
sunshine22 is offline   Reply With Quote
Old 02-20-2011, 06:03 AM   #2
DIY staff
Rewards Points: 7,174
You could cut that little bit of molding with a multi-tool--Harbor freight has one for $29--
A few minutes with a utility knife would also clip the bit out of there--Mike--
I think mitering a 1/4 inch return would work --but look like a mistake.
Old 02-24-2011, 08:39 AM   #3
Rewards Points: 5,336
That molding will not cover the floor gaps, it's too rigid for that. To cover gaps you would use a shoe molding or a 1/4 round or a nose and cove. These are small and could be persuaded to conform to the floors irregularities. They could be installed in front of the colonial base or by itself.
Notch out the back of the molding to cover the vertical vanity molding.
Personally, I would silicone caulk the gaps if they bother you that much and just butt the base molding up to the vanity.
Ron
Tags
baseboard , gap , molding , vanity
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Bland Baseboard Trim tigerbalm2424 General DIY Discussions 17 06-19-2008 11:19 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
Shower / Bathroom Install xlr8tn Plumbing 1 01-15-2008 04:08 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 12:31 PM
