InnerMost Cabinet Doors - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 08:43 PM   #1
biggles's Avatar
InnerMost Cabinet doors
went to flip some upper doors for a different opening swing,loosened the door bracket inside the cabinet easy lift out...but went to relocate the hinge assembly 180 degrees the Phillips screws only turned 1/2 turns.the holes are drilled out up the inside of the cabinet for what looks like a plastic anchor plate that the screw locks into...does the hinge pop out with the screws in place...lost?i went in with a screw driver and wondered why it wasn't unscrewing
Old 08-26-2013, 10:16 PM   #2
Rewards Points: 13,250
Need a picture to see what hinges you have.
mae-ling (08-27-2013)
Old 08-27-2013, 11:11 AM   #3
biggles's Avatar
loosened one screw top and bottom removed the door with its hardware...the cabinet hardware was the problem...see those pre drilled holes both sides on the inside of the cabinet.looks like some kind of anchor clips into the 2 for the hardware screws ..on the left there,but using a Phillips screwdriver only got 1/2 turn on them...they don't screw into the cabinet wood just into the pre drilled holes.maybe 3/8ths diameter..thanks
Old 08-27-2013, 12:05 PM   #4
Rewards Points: 12
Can you post a pic with the door and hardware removed?
Dan
djlandkpl is offline   Reply With Quote
Old 08-27-2013, 05:49 PM   #5
biggles's Avatar
thanks but i'm not at the home where they are will get back after the weekend...with pix of the actual cabinet with door removed don't even know if that is the brand of cabinet,but it looked like the Innermost ones at HD
Old 08-27-2013, 06:42 PM   #6
Rewards Points: 12
I'm interested in the hinge. Some hinges use a plastic/nylon bushing that goes into a hole drilled into the cabinet. The hinge is then screwed into the bushing. The top screw in your pic looks to be an adjustment screw, not one that fastens the hinge to the cabinet.
Dan
Old 08-28-2013, 08:40 PM   #7
biggles's Avatar
there has to be a plastic anchor to hold the hinge without the door attached...mystery was I couldn't remove the Phillips screw holding the cabinet hinge half the holes were factory drilled so the door can be flipped 180degrees actual pix...to remove the door just loosen the screw in the slot....the screws on the cabinet interior hinge are the mystery ...
custom cabinet countertop dilemma: notch it or redo? mystic_cobra Carpentry 14 05-12-2011 11:35 PM
Kitchen cabinet doors quincy Painting 13 04-04-2011 03:36 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 12:44 PM
Flipper top cabinet doors Novicecarpenter Carpentry 4 08-07-2009 10:40 AM
