Idea To Block Off Space - Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 11:27 PM   #31
Missouri Bound's Avatar
Originally Posted by dinosaur1 View Post
How to frame it in? I don't have that type of know how.
It depends on what you want. You may just have to hire a handyman do do it for you. It's really hard to explain construction to someone who doesn't know what to do. I suppose if you wanted to you could pick up some simple carpentry books at the local library or do the research online.....but at any rate you will have to figure out what you want to have when it's finished.........
Old 01-14-2012, 11:44 PM   #32
As my original post stated I don't have any carpentry skills , but maybe there is a different idea someone can give me to block if off a different way.
dinosaur1 is offline   Reply With Quote
Old 01-15-2012, 12:02 AM   #33
Find an old dresser that will block the opening. Use the drawers for the children(s) toys. If you need access you can move it out of the way.
Old 01-15-2012, 08:51 AM   #34
Rewards Points: 2,212
It seems we are kinda going in circles here.
1. Are you wanting to do it yourself or hire someone?
2. What sort of level of look are you going for, piece of plywood hinged on one side and hasp on other -- up to -- double french doors. or some where in the middle?
3. You say you have no carpentry skills, Good time to learn, as stated go to the library (or use google) and read.
With no real skills the double sliding doors are petty easy, install top track, hang doors, bottom guides. Install lock.
4. What all functions does this have to serve/ Block off entire opening, more like a door you can open.
mae-ling is offline   Reply With Quote
Old 01-15-2012, 09:03 AM   #35
Local carpenter wants to charge 2 days worth of labor. I'll pass.
I need to be able to open the door of whatever I put there. Someone even mentioned a curtain. I can do some things myself, but first I need to research all
Up/Downsides.
Old 01-15-2012, 05:30 PM   #36
retired union carpenter
Send a message via Yahoo to coupe
"I need to be able to open the door of whatever I put there. Someone even mentioned a curtain. I can do some things myself, but first I need to research all
Up/Downsides"
maybe? you can handle taking a few thumb tacks and an old bed sheet, and thumb tack it over opening?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-15-2012, 06:37 PM   #37
Up/Downsides"
Old bed sheet?
Old 01-15-2012, 08:44 PM   #38
Old bed sheet?
That's a bed sheet that isn't new.
Old 01-15-2012, 09:01 PM   #39
Yeah I'm not looking for that.
Old 01-15-2012, 09:08 PM   #40
Well....you have been talking about this for a year...do you have any idea what you want? If you knew, we could help you.
Old 01-15-2012, 09:11 PM   #41
It's totally ok. Basically I'm looking for ideas from people who are not carpenters etc.... so I can understand them.
Old 01-15-2012, 09:16 PM   #42
concretemasonry's Avatar
Rewards Points: 2,608
You can nit-pick anything to death for entertainment when it is fast and cheaper to look at a problem, come up with a solution and do it. If it is not satisfactory, just modify it and go on to other projects and appreciate what you have learned in the process.
You cannot have an idea of what you want with no criteria and and expect any agreeable suggestion based on broader experience.
Dick
concretemasonry is online now   Reply With Quote
Old 01-16-2012, 01:32 AM   #43
OK I will still try to help.
No matter what you do it is going to take some carpentry. As I said a bypass door is probably the simplest. You can get locks for this. Do you not like this idea? Why?
Old 01-16-2012, 12:07 PM   #44
Concrete & Masonry
Rewards Points: 580
Put 2 of these in and call it a day...........
http://menards.com/main/millwork/fol...704-c-6261.htm
jomama45 is online now   Reply With Quote
Old 01-16-2012, 03:05 PM   #45
Accordion door is a good idea. You can get them for 60" openings as well.
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 10:47 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
New Guy Cincinnati GB Greg Introductions 3 02-01-2011 07:15 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 07:48 PM
