Idea To Block Off Space - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 06:51 PM   #16
Originally Posted by titanoman
I was just kidding. What are you comfortable doing?
Sent from a Samsung Galaxy S2
Not too much other than buying what I need to hang it up and somehow lock it. I don't want to cut the wall or anything like that. I was considering bifold doors, but they are flimsy and I can see that being an issue.
dinosaur1 is offline   Reply With Quote
Old 01-10-2012, 06:55 PM   #17
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
How big are the kids? How about one of those gates...I don't know what they're called...they look like trellis and they collapse and expand.
I don't know if they go to 57" or not.
But that's pretty light duty.
Never mind. I see you consider bi-folds too flimsy, so a gate won't work.
You might have to hire a carpenter.
titanoman is offline   Reply With Quote
Old 01-10-2012, 06:59 PM   #18
Never mind. I see you consider bi-folds too flimsy.
Whatever I put there I want it to be pretty sturdy which is why I think I will need a pro to do it.
Old 01-10-2012, 06:59 PM   #19
Disabled wood vet
titanoman's Avatar
U see his comment?
What's wrong with "electric fence"?
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (01-10-2012)
Old 01-10-2012, 07:38 PM   #20
DIY staff
Rewards Points: 7,174
It's the internet--and an open forum--largely policed by members like your self.
You did fine reporting it--you did better by asking for more serious answers---Moderator--
Old 01-10-2012, 07:42 PM   #21
Yeah well. People like that belong in "other" forums.
Old 01-10-2012, 07:49 PM   #22
DIY staff
He's not a bad sort--and he left after you asked for more serious answers--so no real harm done--
We could moderate this place to the word --but I wouldn't like a place like that--Better to let the members do some of the work.
Now==back to your original question---
mae-ling (01-14-2012)
Old 01-10-2012, 08:55 PM   #23
As a parent that's very offensive to
me. I'm glad this forum doesn't support that type of nonsense.
Old 01-11-2012, 06:25 PM   #24
Wow i guess this thread is dead hey
Old 01-14-2012, 09:41 AM   #25
A local carpenter recommended the following. any thoughts
"To make the opening more "door friendly", I would propose building a short wing wall on the left side of the opening rather than having the wall pass through the opening without a return at the door as it is now. The opening could be built to any size you determine in order to fit a door. My best estimate for the modification would be about 2 days of labor to build the short wing wall, finish it with drywall, and hang the door."
Old 01-14-2012, 04:09 PM   #26
Rewards Points: 2,202
That is a good solution if you want to change the opening.
I think many of us were thinking of keeping the opening as is.
mae-ling is offline   Reply With Quote
Old 01-14-2012, 05:24 PM   #27
Why is that
Old 01-14-2012, 05:52 PM   #28
For me I thought you wanted DIY and fairly easy to do. Leaving the opening as is is usually easier and often cheaper.
Nothing wrong with filling in one side and putting a door in. Just a little more work and mess with drywall.
Old 01-15-2012, 12:13 AM   #29
Missouri Bound's Avatar
Is that opening the only access to your furnace room? Perhaps the opening is needed as part of return air and access to the equipment. I would just frame it in and install some french doors with a lock and be done with it.
Old 01-15-2012, 12:24 AM   #30
How to frame it in? I don't have that type of know how.
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
New Guy Cincinnati GB Greg Introductions 3 02-01-2011 08:15 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 03:10 AM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 08:48 PM
