Idea To Block Off Space - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 10:37 PM   #1
Idea to block off space
This space is 57 1/2' wide x 80' high. Sort of an odd opening which the previous owner made.
This area is located in a separate room of our basement's rec room and it serves as a play area for our son, his friends and other small children who come over. I need to close this off so nobody goes back to our storage area which also has our water heater, furnace etc....I would love to be able to lock it so nobody can get past it, but if not closing it off at least would be fine.
I do not have any carpentry skills so a Pro might have to do this. Not sure yet.
dinosaur1 is offline   Reply With Quote
Old 01-08-2012, 11:03 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
57 1/2 feet by 80 feet?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-08-2012, 11:28 PM   #3
Rewards Points: 2,212
Are you wanting this to look nice?
Is it temporary?
Any reason for the opening to be this size, what has to go through it?
if wanting to do low cost I am thinking a door in the center with panels on both sides. May need to cut the door down a little.
For it to look 'proper' need to build a wall with a door opening, drywall, baseboard, which you may be able to take from the unfinished area on the other side of it.
mae-ling is offline   Reply With Quote
Old 01-09-2012, 04:15 AM   #4
Retired carpenter
Probably the easiest, fastest, and cheapest solution would be sliding closet doors with a way to lock them.
abracaboom is offline   Reply With Quote
Old 01-09-2012, 06:59 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
A pair of flush french doors would be the quickest fix. Then you can open them to the full width if you need to for access.
Old 01-09-2012, 04:59 PM   #6
Abracaboom has a good idea. could use 2-30" doors which would give you a 27&1/2" opening.
Old 01-10-2012, 11:41 AM   #7
And a pair of hinged 28" doors will give you a 56" opening........... and be easier to lock.
Old 01-10-2012, 11:56 AM   #8
retired union carpenter
Send a message via Yahoo to coupe
I'm assuming that's 57 1/2 inches wide and 80 inches high?
if so? just raise the header to 81 inches, place two studs centered at 38 inches between, get a 36 inch knock down metal door frame, hang 3 foot door and lock set. drywall and finish inside rec room, who cares what storage room looks like? if something over 36 inces but less than 38 inces needs to pass through? simply remove knock down jamb and replace when done
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-10-2012, 12:02 PM   #9
concretemasonry's Avatar
Rewards Points: 2,594
Make sure your solution leaves a 36" wide opening for equipment access and movement, since water heaters and furnaces eventually need removal and replacement.
Just use a slide bolt and passage lockset well above the floor to prevent kids from exploring the dark spaces, but still permit adult access.
Dick
concretemasonry is online now   Reply With Quote
Old 01-10-2012, 01:26 PM   #10
Rewards Points: 150
How about a pair of bi-fold doors.
http://www.shelving-ideas.com/wp-con...loset-Door.jpg
NancyNGA is offline   Reply With Quote
Old 01-10-2012, 05:43 PM   #11
Originally Posted by NancyNGA
Good idea but I cannot find an exact size without it leaving an opening.
Old 01-10-2012, 05:44 PM   #12
I'm not comfortble enough to get that sort of work done.
Old 01-10-2012, 05:46 PM   #13
Is it temporary?
I want to make it so kids can't go back there. The room this picture is in is a kids room downstairs.
Old 01-10-2012, 05:47 PM   #14
Inches
Old 01-10-2012, 05:48 PM   #15
Disabled wood vet
titanoman's Avatar
Inches
I was just kidding. What are you comfortable doing?
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 10:47 PM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 09:32 PM
New Guy Cincinnati GB Greg Introductions 3 02-01-2011 07:15 PM
How to finish closet ceiling in garage space bob22 Building & Construction 2 12-18-2010 02:10 AM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 07:48 PM
