Ibathroom Walls & Floor Question - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2010, 03:58 AM   #1
ibathroom walls & floor question
I am going to have a fiberglass tub installed with a plastic surround. I want to make sure it's done right & I want overkill. It's very wet here in the winter & I will not get the house sided this year. My outside walls are 1/4 " hardwood - un sealed. I decided on Wonderboard under the tub & behind the plastic surround which will be on an outside wall on 2 sides. What is the proper procedure for this installation ? Thanks.
Laura
Laura J. is offline   Reply With Quote
Old 08-12-2010, 08:29 PM   #2
Rewards Points: 5,336
I don't understand the post. Wet outside? No siding? Unsealed?
What does this have to do with a bath tub? If the exterior is compromised, you can't fix the interior.
Please clarify the situation.
Ron
Ron6519 is online now   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 12:54 PM
Installing Plumbing in 2Ē Wide Walls? Robert1_1 Plumbing 5 09-16-2009 08:43 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
