I Think I Made A Big Mistake With My Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 07:03 PM   #1
Rewards Points: 150
I think I made a big mistake with my tile
I didnt bring my backer board down over the lip of my tub because my studs werent straight and it was causing issues. But I figured the tile was big enough to span the distance so it was no big deal. Which the tile does span the distance from the backboard to the tub but theres nothing for the grout to sit on. Anyone have any idea on what I could do? The only thing I can think of is just pump the space full of grout.
Arsinek is offline   Reply With Quote
Old 08-26-2013, 07:08 PM   #2
Rewards Points: 44
You can fill the gap with thinset as you tile. The joint between the bottom of the tile and the top of the tub should be caulk not grout.
Dan
djlandkpl is offline   Reply With Quote
Old 08-26-2013, 07:16 PM   #3
Rewards Points: 150
Problem is the tile is already up.
Old 08-26-2013, 07:27 PM   #4
Rewards Points: 44
Now that there are pics, I see your problem. The tile / tub joint will be OK with caulk. I think the grout joint will be OK if you pack it, but I'm not 100% certain.
Dan
Old 08-26-2013, 07:38 PM   #5
DIY staff
Rewards Points: 7,174
Newbie mistake----slap your self---
You are going to be facing two choices,as I see it---
You can pack that with grout---mix the grout on the thin side---about like yellow mustard---and press the grout in repeatedly until the void is filled---(this can be done successfully)
Second choice would be to remove the lowest row of tiles and pack that void with thinset----
For a good grouting post look at JimF s bathroom thread--or bigjims large porcelain tile thread----perhaps someone can find a link----Mike-----
Old 08-26-2013, 08:13 PM   #6
Rewards Points: 150
Im guessing I would rather try to pump it full of grout. You think that would work?
Old 08-26-2013, 08:28 PM   #7
Haverhill Trade 1965
You could try using a cake decorating bag to squeeze the grout or maybe even a loose mix of thinset in. I would use an elastomeric caulking sealant for the bottom joint, like Lexcel. usually only in white or clear and it is not a latex or silicone. It can reseal itself if cut.
Duckweather is offline   Reply With Quote
Old 08-26-2013, 08:33 PM   #8
Rewards Points: 150
From what Ive read you have a limited amount of time to work with the grout you mix. With having to fix this mistake Im sure its going to take a long time. Can I grout part of the tile then grout the rest some other time? Like the next day or something?
Old 08-26-2013, 08:56 PM   #9
DIY staff
I know it will work,because I have done it---use a soft white grout float --pres and pack--back and fourth---
thin grout---do not tell any one that I was no born knowing everything---
Old 08-26-2013, 09:37 PM   #10
Rewards Points: 150
Ok, thanks for all your help. Youve given me a lot on here.
So thin grout as in when Im mixing it add more water?
Old 08-27-2013, 09:12 AM   #11
When mixing you may want to add a latex additive too. There should be a brand that goes with your grout & one for your thinset. It makes it adhere better and makes it a little more flexible to resist cracks.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
