I Blew It On The Mesurements.Vinyl Window - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-27-2007, 04:00 PM   #1
I blew it on the mesurements.Vinyl window
I already have done two retro fits and Now where the house has wood siding I am doing a new contruction window Dont ask me how this happened but it did,I orderd a 59 1/2 x 59 1/2 window and that is exactly what my rough opening is.
I have not got the window yet and I tried to stop the prouduction but is is to late.
I could get lucky and it fit but I dout it so I am preparing for the worst.
I am wondering what would be the best way to take a little off the rough opening.I think I would only need to take it off the bottom and one side.
Probobley like an 1/8" or a 1/4 "
It pisses me off cause the guy at the place I orderd the window from said if the window that I am removing mesures 59 3/8" then a 59 1/2"
window would be what I wanted I listend because he helped me order the other windows and they were good.I am wondering if he made a mistake and ment to subtract some insted of add some.
I went to the place where I orderd it but he was not there today.
Anyways can any one help me with a tip on trimming the opening up a little.
Thanks Doug
Doug Crf is offline   Reply With Quote
Old 03-27-2007, 05:26 PM   #2
Thanks Doug
If this is a duplicate post my apologies (first one didn't seem to go through).
Anyway... If you have a wood rough-in, could you just use a belt sander to take off a little on each side? I had to do that with a prehung door once.
Ben
bjstewa is offline   Reply With Quote
Old 03-28-2007, 05:08 PM   #3
Rewards Points: 5,336
Wait until you get the window. Sometimes the windows have lips on the side that can be cut down with a utility knife.
Ron
Old 03-28-2007, 07:11 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Ron
As stated, wait to you get the window, then measure and check - to see what the best course of action (alteration to window or siding) would be...for a good fit-ment.
- Build Well -
Old 03-29-2007, 02:01 PM   #5
Ok thank you guys for your time.
Doug
Old 03-29-2007, 04:15 PM   #6
Home Improvement Guy
ron schenker's Avatar
If you do have to cut, how about a power planer?
ron schenker is offline   Reply With Quote
Old 03-29-2007, 11:06 PM   #7
Like the others said wait until you get the windows and adjust whichever is easiest.
A power plane or a sander will work on the framing.
Also I recently ran into a situation where Home Depot screwed me pretty good on the delivery time of some widows for a job I was doing. I went to Store manager and rose hell. I was able to get a 10% refund.
So I suggest bypassing your original salesperson and go directly to the manager and tell him politely of of your extreme displeasure with the misinformation you got.
Who knows maybe you get a store credit or or a partial refund, but no matter what what they will know how you fell.
jiggyjack is offline   Reply With Quote
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Double hung window trim helpless handyman Carpentry 24 04-10-2007 09:49 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
