Hydronic Baseboard Mounted To Concrete Wall - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 10:48 AM   #16
DIY staff
Rewards Points: 7,174
Originally Posted by tylernt View Post
I would make the nipple between elbows a wee bit longer so you can get solder in there better. I'd also make up the elbow-nipple-elbow on my workbench beforehand, so I wasn't working on the floor so much.
I disagree---the solder will flow--and soldering a part of an assembly first--then hoping that it is clean enough to add to your piping? Never works well for me---
We all have systems that work for us but not well for others---this would not work well for me---
Old 12-23-2012, 11:01 AM   #17
Special User
Rewards Points: 1,230
Originally Posted by oh'mike View Post
soldering a part of an assembly first--then hoping that it is clean enough to add to your piping? --
True, though I do clean the remaining fitting after soldering the assembly and letting it cool...
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following User Says Thank You to tylernt For This Useful Post:
oh'mike (12-23-2012)
Old 12-25-2012, 10:18 PM   #18
Success!!
All soldered up and holding pressure! I think I even got the entire system bled too.. Also changed the waterlogged expansion tank too.
Thanks for the advice on this one!
I have another question about filling the hole in, but I think I will start a new thread on that one.
Maine1 is offline   Reply With Quote
Old 12-25-2012, 10:40 PM   #19
Missouri Bound's Avatar
Before you start a new thread and fill in that hole...keep in mind that that pipe is going to want to move a bit when it heats and cools. Give it room to do that.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
oh'mike (12-26-2012)
Old 12-25-2012, 10:59 PM   #20
Your right. It originally had black foam insulation around it. I will do the same.
I posted another thread about filling in the concrete in the concrete forum.
Old 12-26-2012, 07:08 AM   #21
DIY staff
Nice clean work! Do replace the foam--good job!
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 07:46 AM
Drywall on interior concrete basement wall marlenec Drywall & Plaster 1 07-18-2011 11:22 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
