How To Tile Shower Ceiling? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 04:35 PM   #1
Rewards Points: 150
How to tile shower ceiling?
On to the next step.
Ill be having to tile my shower ceiling. Im using 6 inch tiles. How do I go about doing this?
Arsinek is offline   Reply With Quote
Old 07-30-2013, 10:38 AM   #2
roofingquotes's Avatar
You can try try the ladder.
roofingquotes is offline   Reply With Quote
Old 07-30-2013, 11:01 AM   #3
Rewards Points: 5,974
I assume you mean how to get them to stick till they dry. Make your thin set a little stiff. then when you set the tile wiggle it a little to set it in the mud. 6" is not very heavy so you should not have any trouble
Old 07-30-2013, 07:30 PM   #4
Rewards Points: 150
Ok.
So I dont really need to do anything special?
Old 07-30-2013, 08:10 PM   #5
firehawkmph's Avatar
Rewards Points: 1,826
Arsinek,
they do make thinset with more grab to it for setting heavier tiles and stone type products on vertical walls. But like Toolseeker said, 6 x 6's shouldn't be a problem.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 07-31-2013, 03:19 AM   #6
Too Short? Cut it Again!
If you are using tile spacer things to press tile into the thinset or whatever and hold to your grid? You might want to have at least two over what you planned as needed in a tool belt pocket or something with regard to spacers. I personally have never, never, ever dropped one.
Had I ever dropped one, worth $.0245US in quantity, my clients would have screamed.
Have not heard about a shower/bath ceiling being tiled in quite awhile. Why? Just curious.
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 03:11 PM
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 08:39 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
